  3. Fotos e Vídeos
  4. John shepherd, eclipse
20 Posts 13 Posters 2.5k Visualizações 1 Watching
    daniel
    chassis & interior
    factory unibody chassis
    autometer gauges
    all steel except for hood and hatch
    gary reese 7.49 certified cage
    momo steering wheel
    kirkey seat
    jic coilover suspension
    the brake man front and rear brakes
    volk 15x7 bronze te-37 wheels
    mickey thompson et drag tires
    engine
    buschur racing 2.0l short block
    je pistons
    groden aluminum rods
    eagle 4340 crankshaft
    hard block filled block
    stock oil pump and pan
    fox lake power products cylinder head
    race port intake and exhaust
    1mm ferrea intake valves
    1mm ferrea exhaust valves
    ferrea dual valve spring
    o-ringed deck
    custom grind crane cams
    unorthodox cam gears
    ams vsr intake manifold with 90mm throttle body
    fuel, ignition, & engine management
    buschur racing dual fuel rails
    10 x 1600 cc injectors
    methanol fuel
    3 gallon fuel cell
    waterman mechanical fuel pump
    aem engine management
    aem wideband kit
    aem injector driver box
    msd dis 2 ignition box
    buschur racing coil on plug coils
    16v turbostart battery
    nitrous express nitrous system jetted for 100 hp
    drivetrain
    sheptrans.com dog box transmission
    act carbon clutch
    the driveshaft shop aluminum driveshaft
    the driveshaft shop transfer case upgrade
    the driveshaft shop stage 5 front axles
    turbo & exhaust
    forced performance 321 stainless header
    tial blow off valves
    tial 44mm wastegate
    forced performance gt42r turbo
    ams 3.5 upper pipe
    forced performance 3.5 side exit exhaust
    hallman boost controller set to 55 psi
      4cil 2000cc????
      ta loko
      babei
        55 psi
        :putz:
          3.85 bar…
          mermao, isso é tempo/velocidade do degreas...
          mais o cara tem 2 cil. a menos de 1/3 da cilindrada pqp
          quem disse que no have replacement for displacement? :putz:
            FabioRR
            esse da? segue o lema:
            quem tem medo de pressão, é art?ria entupida
              gabriel
              pqp sem palavras…
                Le
                carrao mesmo
                lembro dele quebrando o cambio na final da nopi de 2005
                voou pedaão pra tudo quanto é lado.
                  BRUTaL DLX
                  du caralho este
                    Bruno Ramos
                    nossa, animal demais esse eclipse…
                    gagina ele alinhando com o ybl e com a ss-10 do alexandre...
                      turbocahrger is the best replacement for displacement.
                        Mega
                        segundo me consta, esse carro é 2.7 lts.
                          fraco… fraco nao ... raquitico
