  4. Qual a diferença entre weber ida e idf
46 Posts 19 Posters 6.9k Visualizações 1 Watching
    já tive essa dúvida e recebi explicação igual
    idf é pra rua e ida é pra pista
    mas não souberam responder o que mudava de um modelo pro outro
    [snapback]610231[/snapback]
    não seria por cauda daquilo q eu disse sobre não ter o sistema de injeção rápida e tb o sistema de progressão?
    sem esses dois sisteminhas qq carro fica quase q indirigivel em baixa/média rotação. ja em alta esses sistemas não fazem falta alguma.
      RodrigoLóke
      pessoal, segue resposta da redline weber não vou traduzir pq esta tarde e eu estou morrendo de sono só estou postando aqui, porque prometi colocar a resposta. amanha respondo os post de todos ok ?
      with that in mind best street application would be the idf style it is a more flexable and easier to tune package.
      for pure performance the ida is best.
      the ida is a larger taller body and was the origonal cobra style four carb package.
      the idf is a carb with same bore but more compact and more current circuit designe so it offers a little wider tuning range but from a race stand point it does not offer the total peak performance.
      it is a race based carb so it is picker to tune but due to its longer length (taller) it does offer a better max rpm power point.
      the ida only has advantage at wide open throttle and very high max rpm range in the 0 to 5000 rpm range they will be the same it is only on the track that you would see the differance.
      i will try to get you some pictures to view the differance i will send those with the quote
      bud pauge
      redline weber
      general range for priceing 2000 for the idf complete package with fuel lines and complete assebmly,
      and about 2800 dollars for the ida complete with total package fuel lines fuel fittings total package ready to go.
      i will get with sales to confirm specific pricing
      both kits will offer 48 mm throttles.
      i would have hoped that they would have replied to you by now. with a dealer or direct reply. im sure my pricing is at least in the range or close for your referance
      quando eles me mandarem as fotos, posto aqui para o pessoal
        no post do láke ja tem as diferenças entre as duas, pelo que meu péssimo ingles percebeu
          RodrigoLóke
          se não me engano até o coletor das ida é diferente das idf, pois elas tem as borboletas mais afastadas. são grandes tb, e tem poucas opções de tamanho.
          qto ao quadrijet, veja o que vc vai usar no v8, pois os monstros de rua daki de cwb não usam mais q uma 750cfm, pois mais que isso não fica legal, sobra carbura e falta motor.
          se for usar comando razoável, pouca cilindrada a mais, cabeçotes de ferro trabalhados, provavelmente a gasolina, nem esquente a cabeça com mais que 650cfm q tá loco de bom.
          como diz a lenda, nem sempre mais é mais.  :o_o:
          [snapback]610203[/snapback]
          você está certo gus, 650cfm está mais do que bom mesmo a única possibilidade que me encanta é possuir um duto de ar para cada cilindro as possibilidade de ganho com esse sistema são muitas de qualquer forma, to vendo que o custo ficaria fora de controle vou manter a conf. original mesmo viu
          lóke,
          se o negócio for usar 8tbi, faz logo injetado.
          ai eu te dou uma mão com o que to fazendo aqui. tanto injeção quanto ignição.
          [snapback]610227[/snapback]
          esse é um sonho antigo e uma realidade futura mas no momento acho que vou ficar no meu mundinho mesmo hahaha
          depois eu pego a solução pronta contigo :ppteam:
          segue a tradução do texto do pessoal da redline para vocês. eu odeio traduzir ao po da letra, portanto estou escrevendo a minha interpretação do texto.
          com isso em mente, a melhor aplicação para uso em rua será o tipo idf, pois é mais flexivel e de facil ajuste.
          para performance pura, ida é o melhor. ida possui um corpo mais alto o kit de carburadores do cobra.
          o idf é um carburador com o mesmo diametro, porém mais compacto e desenhado para circuito, possui ligeira melhoria na
          possibilidade de ajuste porém pelo ponto de vista de corrida, não oferace o melhor performance.
          o ida somente tem vantagem sob borboleta totalmente aberta e a potencia a um elevado rpm, porque em um range de
          0-5000 rpm ambos possuem a mesma performance. somente na pista que você ver? a real diferença entre os dois.
          eu tentarei pegar algumas figuras para mostrar a real diferença e enviarei estas figuras com a cotação.
          de forma geral, o preão é de usd 2000 para um kit completo com linhas de combustável para carburadores idf e
          aproximadamente usd 2800 para um kit completo de carburadores ida, ambos prontos para montar.
          eu lhe passarei para a pessoa de vendas para confirmar o preão exato.
          ambos os kits são com borboletas de 48mm.
          eu espero que lhe retornem brevemente. eu estou certo que o preão ?, pelo menos, nessa faixa ou muito proximo desta
          referencia.
            rodrigo, vc poderia confirmar com eles se as ida tem ou não o sistema de injeção rápida e os furos de progressão?
              RodrigoLóke
              [snapback]610331[/snapback]
              claro, posso sim chegando em casa eu mando um e-mail para eles ok ?
                DuKa
                a unica coisa que eu nao entendi é se esse kit ja sao os 4 buras, com acionamento, linhas coletor, etc…
                se for isso, sai menos de u$500 cada bura novo... ai pros carbureiros de plantao, seria uma ótima opção...
                  resumindo: as ida tem o corpo maior e mais longo ….. proporcionando assim, melhor desempenho em altos rpm.
                  tinha que ver o lance dos ajustes que a carol perguntou, mas pelo que eles falaram que as idf são melhor ajustaveis eu acredito que não tenha, não....
                  se algume tiver aqueles esquemas visão explodida das ida dá pra ver se tem ou não............ :ppteam:
                  no mais..................... coloca o quadrijet, rodrigo
                  abraão
                    Godones Motorsports
                    fire… fire... fireeeeeee
                    pq amigo é para essas coisas
                    lóke, quer aquele projetinho de novo? :ppteam:
                      GusWRC
                      eu acho q um kit de 4 weber com coletor não sai por menos de us$ 3000, l
                        lóke, quer aquele projetinho de novo? :hauhau:
                        [snapback]610396[/snapback]
                        nossa… sem palavras... :ppteam: :o_o: :hauhau: :hauhau:
                          m4c4c0
                          _to quote from hpbooks weber carburetors by pat braden:
                          the prefix always indicates the size of the throttle plate i.e. 40 dcoe is a 40mm throttle plate. the letters immediately following the prefix refer, in italian, to the general type of carb. only a few terms are consistent: dc means doppio corpo, or double-throat. v means verticale (vertical) and o means orizzontale (horizontal). the i in ida seems to mean invertito, or inverted. yet, there are no updraft, or inverted, webers; the ida is a downdraft.
                          other even less-consistent single-letter designations are:
                          ? e: die cast carb
                          ? f: ford (of europe) or ferrari (?) application
                          ? v: carb with power valve
                          ? a: water-operated automatic choke
                          ? g: progressive rate
                          weber carb nomenclature is chaotic. the ida may be 2-3 throats, and there is no choke at all. the e in dcoe indicates either a trapezoid bolt pattern (in some applications), or a rectangular pattern. the dcn fitted to the lamborghini was a dcnl, but if fitted to a ferrari, became a dcnf_
                          seria o idf, portanto, uma versão civilizada do carburador de pista para a ferrari de rua???
                          :ppteam:
                            Rafael16V
                            [snapback]610234[/snapback]
                            sim carol :(
                            quis dizer que na época não souberam responder, só que comi um peda?o
                            tentiva frustrada de subentender que agora foi explicado :pix:
                              FabioRR
                              mete a 4jet … se ficar fraco vai de nitro
                              :pix: + :banguela:
                                [snapback]610352[/snapback]
                                ja responderam? :(
                                sim carol :^^:
                                tentiva frustrada de subentender que agora foi explicado  :^^:
                                [snapback]610867[/snapback]
                                não repare, é q ja fui loira :^^: :pix:
                                  lóke, quer aquele projetinho de novo? :(
                                  agora imagina um blower em baixo disso ae :^^: :pix:
                                    [snapback]610899[/snapback]
                                    tipo assim ? ? :^^:
                                      RodrigoLóke
                                      ja responderam?  :pix:
                                      [snapback]610886[/snapback]
                                      carol, eu tinha esquecido de mandar…... :^^:
                                      acabei de mandar o e-mail. assim que eles responder eu posto. :(
                                      abraço,
                                        Rafael16V
                                        ja responderam?  :^^:
                                        acabou com as loiras agora :p
                                          RodrigoLóke
                                          vamos lá pessoal, estou abusando do carinha lá da redline hehehe dá até vontade de comprar, só pela atenção que o cara está dando
                                          dessa vez não vou traduzir não, não to com saco hahaha
                                          there are many smaller differances in the two carb styles. which is why one offers more flexability for tuning street only. but yes the idf does offer a choke / cold start device but that system does not offer a fast idle choke system. and no we do not offer a progressive system both sets have common cross bar linkage for smooth throttle action and funtion as single throttle opening at one time.
                                          i was trying to keep things compact for your information and i seem to have made things more confusing.
                                          i hope the pictures will help
                                          im sending in two parts this one contains the idf 302 kit note the linkage is simple single pull interconnect so all linkage functions as 1.
                                          note also that we remove the cold start device to clean up the look and mount blanking plates to cover this function. we can supply complete but find that it should not be needed for a well tuned set up.
                                          my next e mail will supply the ida set up
                                          bud pauge
                                          redline weber
