  3. Fotos e Vídeos
  4. Cossie + bbs
Cossie + bbs
111 Posts 25 Posters 14.4k Visualizações 1 Watching
    gosto é gosto mas esse aero faz 19 kg na traseira do cossie.
    parado, né ?
    imagina à 220km/h ??? :)
      parado, né ?
      imagina à 220km/h ??? :teteto:
      ele faz isso a 180 km/h, e funciona tão bem q a ford correu uns bons anos com esse aero original no wrc
      aliás, esse aero varal foi esculpido em túnel de vento, assim como os spoilers dianteiros (que também geram sustentação negativa
        Padula
        an incredibly famous engine, the cosworth yb turbo actually began life in 1984 as a n/a cosworth yaa concept. however, the turbo version was launched in the 1986, 3 door sierra with 204bhp. the infamous rs500 version of the same car followed in 1987 with 225bhp, a bigger t4 turbo, eight injectors (only four connected) and an engine designation of ybd.
        perhaps the most plentiful sierra, the sapphire hit the roads between 1988-89 with a 4x4 version being produced from 1990-92. the engine was subsequently available in two versions for this latter car – the ybj, which incorporated many of the rs500 motorsport type revisions, plus the green cam covered ybg, meant for the us emissions sensitive market. this had three cats, closed loop lambda control and ran on 95 octane unleaded.
        finally the escort cosworth took over from 1992 with the big turbo ybt engine, featuring a t34 and four wheel drive, whilst the series came to a halt with the introduction of the t25, small turbo escort between 1994-96. this also featured ford eec iv management, with wasted spark ignition, twin coils, a different series of injectors and a unique black cam cover.
        ford cosworth yb 16valve turbo engine
        the most common engine is the original ybb (3 dr and 2wd sapphire), which can be easily tuned with chip and turbo modifications to increase the boost level. however, the 4x4 head is the ideal base since the early type has less water jackets and is susceptible to blowing head gaskets with serious hikes in boost.
        to begin with, you’ll need to upgrade the actuator to -31 (dash 31) type and upgrade the management chip to increase the fuel and boost level too - this will typically be to around 270/280bhp. we would recommend that you also fit a good stainless exhaust such as our mongoose range, plus a k&n filter.
        after that stage, you need to swap the injectors for 803s – commonly known as dark greens. to this you’ll need a different chip again, plus a 3-bar map sensor to up the boost to 19 psi (1.3 bar) resulting in approximately 320-330bhp.
        beyond this level, we’d recommend fitting a group a or multi-shim head gasket and for extra security in high-boost applications, and an arp stud and nut kit.
        however, around this level, the standard garrett t3 turbo will have reached its limit although there are now several paths to take in turbo choice. these though are always a trade off between turbo lag and driveability – hence why going straight to a t4 isn’t always a good move. popular choice is to fit an escort t34 or a hybrid t3 along with a larger intercooler. t38’s are also available although these aren’t an off-the-shelf garrett unit and are seen more as a hybrid. you should see power potential with this to around 460bhp, whilst the t34 will give you power to around 380bhp.
        at this point – and especially if you want to use a t4 with power potential to the touring car levels of 540bhp - the engine needs to be purpose-built to suit. the reason is you’ll need extra head work in terms of porting, different cams (although bd14s are the limit on the street), lower compression ratios and long stud conversion. the trick is making the most of the unit whilst producing power without huge amounts of lag. once you get to this stage, we can advise you on the best way forward, depending on the type of engine you have.
        a different route, and still popular way to tune the yb, is to return it to the original n/a application, which involves raising the compression. for this, we stock accralite forged pistons to increase the ratio to as much as 12.5:1 although they can be machined to lower the cr since they have raised crowns for this purpose.
        on top of this modification, the head needs the ports seriously opening out and for ultimate horsepower applications, larger valves installed. the cams too need swapping for non-turbo profiles although they aren’t designed to work with the standard yb hydraulic lifters and therefore need converting to solid lifter type.
        the bottom end is fine for this type of aspiration since the rods and crank are both steel. we would recommend however, that the rod bolts are upgraded for high-revving applications. for ultimate power though, we also stock steel h-section rods. lastly, you will need to swap the turbo inlet manifold for a twin dcoe type allowing either 45/48 side draughts or throttle body fuel injection. in this form, you should be able to achieve in excess of 225bhp+.
        copiado descaradamente da burton power.
          Milho
          provavelmente muita gente ja viu:
          getaway in stockholm 2: toyota supra and ford escort rs cosworth
          é bonito de se ver (ouvir). fora o supra que nem tem o que falar né…
          ainda me lembro quando vi esse video pela primeira vez (acho que foi em 2002 ou comecinho de 2003) na mesma epoca que saia os oktane rnr.
          colocava os fones de ouvido quase no máximo e ficava vendo gis 2 durante horas…
          :teteto:
          quanto ao cossie, o jeremy clarkson é o maior paga pau de todos os tempos desse escortinho.
          teve até um top gear que ele fez uma comparação do escort com o focus rs turbo... e o escort deu pau...
            se voce procurar no google, um pouquinho só, voce entenderá o porque desse aero.
              tchê, eu me refiro a pressão aerodinâmica. tirei isso da 4 rodas, hehe.
                não lembro aonde eu li, mas era mais que isso.
                  GusWRC
                  esse aqui eu fico de cara, tem altas fotos tesão desse carro na net:
                  o dono é stian hafsengen, anda direto no gatebil na suécia. o legal é que foi um carro do carlos sainz e ainda melhorado tem mais de 700hp, montado inteiro com componentes de primeira, forte e resistente, bem do jeito que eu gosto. apesar do azul nesse tom e dessa asa não serem os meus favoritos, vai na boa principalmente com as rodas brancas
                  <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/qbffokzcbta&amp;fmt=18"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/qbffokzcbta&amp;fmt=18" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
                  <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/1zmmztos82a&amp;feature=related&amp;fmt=18"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/1zmmztos82a&amp;feature=related&amp;fmt=18" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
                  <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/4l_m-b30530&amp;feature=related&amp;fmt=18"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/4l_m-b30530&amp;feature=related&amp;fmt=18" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
                    isso deve andar uma barbaridade hein gus :teteto:
                      GusWRC
                      mais um bom:
                      <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/uhfconuphu4&amp;feature=related&amp;fmt=18"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/uhfconuphu4&amp;feature=related&amp;fmt=18" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
                      • 0 Offline
                        0 Offline
                        036ullivan
                        aff maria …. que coisa maravilosa esse cossie hein gus.... p... vídeo tbm...
                          meu deus o que foi a construção desse foguete?
                          isso é digno de grupo b
                            Edu4rdoBR
                            infarto geral
                            eu pesquisei aqui, e tem um único cossie aqui no japão pra venda,não tem valor, mas a loja fica a 30 minutos de trem daqui. dá vontade de ir ver :teteto:
                            edit: http://www.goo-net.com/used/spread/goo/13/…0080705001.html
                              GusWRC
                              infarto geral
                              eu pesquisei aqui, e tem um único cossie aqui no japão pra venda,não tem valor, mas a loja fica a 30 minutos de trem daqui. dá vontade de ir ver :humpft:
                              vai lá, compra, depois trás pro brasil e me vende :teteto:
                                Shark
                                mais fácil tentar comprar o que tá no rio … :teteto:
                                  infarto geral
                                  que lojinha lazarenta, hein
                                  além do cossie tem 3 lancia delta integralle (amarela, azul, vermelha), lancer evo branco, etc.
                                  :teteto:
                                    eu quero o delta vermelho :teteto:
                                      :teteto:
                                      esqueceu de comentar sobre o peugeot 106 gti (segundo o jeremias carloson o ff mais divertido de se dirigir) e o spoon fit
                                        aquele top 100 é hilário. ele faz uma pizza com o 106.
                                        babei no anúncio, eu curto esses faróis redondos. só colocar ummas speedline ouradas e é meu escort absoluto.
                                        mas já me contento com o delta amarelo. :teteto:
                                          GusWRC
                                          edu, qto custa um carro desse ou um delta em dóla?
