  3. Fotos e Vídeos
  4. C6 corvette twin turbo
21 Posts 16 Posters 2.0k Visualizações
    Shark
    :humpft:
    lord vader, your car is ready.
    specs-
    car: 2005 corvette z51 6-speed blk/grey, nav.
    block: sdpc
    displacement: 402 cid
    compression ratio: 9.5:1
    heads: west coast cylinder heads stage ii
    valves: stainless rev 2.02 intake and 1.57
    camshaft: lapd custom grind 230/230 115lsa
    rocker arms: comp cams 1.7 ratio
    pistons: manley 2618 -14cc dish
    crankshaft: callies 4340 crank
    rods: scat h-beams 6.125”
    intake manifold: fast 90mm composite
    throttle body: 90mm ls2
    fuel injectors: 60-lb mototron low impedance
    fuel pump: stock gm, magnavolt fuel pump booster
    fuel supplement: alkycontrol progressive kit (dual nozzle)
    ignition: stock coil packs, msd 8.5 mm plug wires
    engine management: stock gm pcm, hp tuners speed density tuned by doug stalter @ los angeles performance division
    power adder: aps twin turbo c6 system (modified)
    maximum boost: 14.5psi
    intercooler: dual aps high-efficiency intercoolers
    turbo actuators: forge motorsports billet
    blow off valves: forge motorsports billet
    exhaust system: kook 3” mid-section, b&b bullet, royal mufflers custom fabrication.
    transmission: stock t56 six speed, callaway short shifter
    clutch: gm ls7
    driveshaft: stock
    front suspension: pfadt racing coilovers; hotchkis sway bars
    rear suspension: pfadt racing coilovers; hotchkis sway bars
    rear end: stock with 3.42 gears
    front brakes: wilwood 14” sl6- piston, polymatrix pads
    rear brakes: wilwood 14” 4-piston, polymatrix pads
    current mileage: car- 14,800 miles, engine- 5,000 miles
    exterior-
    lingenfelter commemorative edition c6 custom hood
    z06 rear quarter panel conversion by jim bainbridge @ rydell van nuys
    wcc carbon fiber rear exhaust panel
    custom carbon fiber brake light spoiler
    wheels: c6 z06 aftermarket; 18x8.5 fronts, 19x12 rear blk powder coated “time attack red”
    front tires: michelin pilot sport 2, 245/40/18
    rear tires: goodyear f1 supercar emt, 325/30/19
    custom a-pillar carbon fiber
    blackouts: emblems, tail lamps & side markers
    bi-turbo emblems…
    interior-
    blitz sbc i-color electronic boost controller
    autometer cobalt gauges: boost, fuel pressure and wideband
    callaway short shifter (oem knob)
    lingenfelter lpe logo floor mats
    lingenfelter lpe logo trunk mats
    underhood amenities-
    lingenfelter fuel rail covers (blk. w/red lettering)
    carbon by design: cf accesories
    optima yellow top
    lapd clutch bleeder
    west coast corvette blk aluminum engine cap set
    fotos do kit :olhos:
    :olhos:
      :humpft:
        RodrigoLóke
        simplesmente perfeito
          pior que ainda deve ter uma margem de segurança absurda…
          sem contar que é lindo, amo corvette
            lindo.
              m4c4c0
              faltaram os aros das rodas polidos e as lanternas traseiras vermelhas. e os documentos no meu nome.
                não quer mais nada? :humpft:
                não tem o que falar, perfeito.
                  Inssurection
                  afeeeee sem comentarios
                    celso
                    fantástico virou papel de parede
                      vwfan
                      esse merece o meu selo oh my de qualidade
                        goiano
                        qual a potencia é 750cv ? ? ?
                        o que o mestre lingenfelter tem haver com esse projeto é :(
                        bomba de combustivel original ?
                        embreagem original ?
                        ignição original ?
                        caraio…..........parabéns.............
                        lord goiano: seu carro tá ready :hauhau:
                        ps: vou deixar passar essas rodas de f-430 pq também adoro ferrari............ :ohoh:
                          goiano
                          ignição original ?
                            Mauricio Bozo
                            eu só tirava esse aro vermelho das rodas… e deixava as lanternas vermelhas...
                            ps: vou deixar passar essas rodas de f-430 pq também adoro ferrari…......... :ohoh:
                            essas sao as rodas originais do z06…
                              goiano
                              essas sao as rodas originais do z06...
                              eu quis dizer que assim pretas e com bordas vermelhas ficou lembrando as rodas da ferrari….. pelo menos pra mim....
                              por isso coloquei bem entre aspas .....heheee......... :ohoh:
                                goiano
                                parece, né ? ? :ohoh:
                                  Mauricio Bozo
                                  por isso coloquei bem entre aspas .....heheee......... :hauhau:
                                  ahnnn, achei que tu tinha pensado que fossem rodas de f430….. e realmente, lembram as rodas da f430...
                                  edit: as rodas desse corvette ai, tinham que ser pintadas de preto fosco e não deveriam ter a borda vermelha.
                                  ps.: esses tempos eu vi um z06 preto, com as rodas originais cinza chumbo... :ohoh: ficou bacana tb
                                    :infarto:
                                      streit
                                      vou mandar pintar o meu tb. :ohoh:
                                        vou mandar pintar o meu tb. :hauhau:
                                          Vitinhu_Pinho
                                          animal hein
