Diagrama do motor ap
galera comprei um ap 1.8 parcial e gostaria de ver todas as peças que compoe o motor ap.
pra ver oq ta faltando
vlw abraços
e aqui vamos denovo.
sendo :
cylinder head
head gasket
valve cover
valve cover gasket
intake valve
exhaust valve
valve seals
valve springs
valve spring retainers
valve keeper
valve lifters
camshaft
front cover gasket
front cover
camshaft gear
timing belt
idler pulley
piston ring set
pistons
connecting rod
bearing
bearings
crankshaft
rear main seal
pulley
flywheel
ring gear
oil pan
oil pan gasket
oil pump
deus lhe abenãoe irmão
a pedidos:
cylinder head - cabeçote
head gasket - junta do cabeçote
valve cover - tampa de válvulas
valve cover gasket - junta da tampa de válvulas
intake valve - valvula de admissão
exhaust valve - valvula de escape
valve seals - selo das valvulas
valve springs - mola das valvulas
valve spring retainers - retentor de valvulas
valve keeper - trava das valvulas
valve lifters - tuchos
camshaft - comando
front cover gasket - junta da tampa frontal
front cover - tampa frontal
camshaft gear - polia do comando
timing belt - correia dentada
idler pulley - polia
piston ring set - anéis de seguimento
pistons - pintões
connecting rod - bielas
bearing - mancais
bearings - mancais
crankshaft - virabrequin
rear main seal - selo do volante
pulley - polia
flywheel - volante
ring gear - anel da polia inferior
oil pan - carter
oil pan gasket - junta do carter
oil pump - bomaba de óleo
… me corrijam se errei alguma coisa.
