  4. Norton nrv588 rotary-powered
13 Posts 11 Posters 1.3k Visualizações 1 Watching
    Shark
    undoubtedly, the company that s most often associated with rotary engine technology is mazda. the japanese automaker has been building wankel powerplants for decades, with the current rx-8 standing alone as the only new automobile powered by the innovative engine architecture. in reality, though, many firms have experimented with the rotary engine, including suzuki, which offered a rotary-powered motorcycle in the seventies. up until the mid-nineties, european racetracks were filled with the buzzing sounds of wankel-engined norton motorcycles terrorizing their larger four-stoke twin-cylinder competitors and winning races such as the isle of man tt in 1992.
    that unmistakable buzzsaw sound is set to make a comeback at this year s running at the isle of man as the latest norton revival takes to the track. click past the break for a video of the rotary-powered nrv588 as it makes a few laps at donington park and the dyno. pay special attention to the exposed exhaust pipes, which reportedly get so hot they need to be made from inconel.
    **engine:
    588cc twin-rotor wankel type
    fuel injected, direct spray into both bell mouths
    fully variable intake tract to peak maximum torque between 8000-11,000rpm
    electric water pump
    ducted fan air cooling for rotors
    fly-by-wire throttle
    power: projected at 170 bhp @ 11,500 rpm
    max torque 80 ibs ft, at variable rpm
    chassis: twin spar aluminium, by spondon
    front suspension: ohlins upside-down fork
    rear suspension: ohlins specially made long-stroke single-sided direct connection unit
    brakes: ap discs with radial mounted front callipers and rear 2 piston brake calliper.
    wheels: dymag 16.5in
    tyres: dunlop
    weight: 130kg (dry)
    http://www.nortonracing.com**
    :jaca:
    <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/ph-n7-naqxo"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/ph-n7-naqxo" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object>
    http://www.youtube.com/watch?v=ph-n7-naqxo</center>
    <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/48foohk2tya&amp;feature=related"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/48foohk2tya&amp;feature=related" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object>
    http://www.youtube.com/watch?v=48foohk2tya&feature=related</center>
    :ohoh:
      aqui no trabalho não rola seutubo e mesmo assim, so conhecia o norton antivirus e aquele ator que pereceu a algum tempo.
        Fiasa Power
        rotary power
          Rafones
          e aquela fumaça de motor 2 tempos, normal nos rotary?
            k1llm4ster
            fuma muito hehehehhe
              Fiasa Power
              não tão normal nos mais novos … mas ainda sim , normal .
                WEST
                pqp, que tesão 170hp e 130kg…
                como diz o jeremy clarkson:
                “they (supercars) are designed to melt ice caps, kill the poor, poison the water table, destroy the ozone layer, decimate indigenous wildlife, recapture the falkland islands and turn the entire third world into a huge uninhabitable desert.”
                eheheheh deixa a moto fumar.. :jaca:
                  gostei do sistema de coletor variavel deles … pelo menos eh o que parece no segundo video.
                  e quanto a fumar, eh pq motor wankel eh lubrificado com oleo 2t... não tem como colocar oleo dentro desse motor...
                  no mais rotary power :ohoh:
                    rbsmontemor
                    :ohoh:
                      eheheheh deixa a moto fumar.. :humpft:
                      ele diz isso naquele episódio que compara supercarros velhos com os atuais né?
                      rotary power
                      • I Offline
                        I Offline
                        Inssurection
                        afeeeeeeeeeeee
                        motor wanken pra mim eh o chuta bundas da vida
                          Marv
                          alguem ai tem o link do episodio onde o jeremy clarkson compara os supercarros velhos com os atuais??
                            aqui.
                            <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/y3qvhjbmhk8"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/y3qvhjbmhk8" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object>
                            http://www.youtube.com/watch?v=y3qvhjbmhk8</center>
