  3. Fotos e Vídeos
  4. Palatov dp4
Palatov dp4
7 Posts 4 Posters 1.2k Visualizações
    http://www.youtube.com/watch?v=uwqjmyynys0
      http://www.youtube.com/watch?v=jegnm6lvxyu
      [site do construtor](site do construtor)
      show hein, pena não vender aqui…
        duplicado, favor apagar
          Gui_Jpa
          the dp4 is designed to make genuine race car performance accessible to trackday enthusiasts at a modest cost. it features advanced underbody aerodynamics, a long arm double wishbone suspension with pushrod activated coilover dampers and an optional all-wheel drive system. power comes from a variety of motorcycle engines with typical configurations using 1.0l or 1.3l units of 175-200 hp. typical weights are in the 800-900 lbs (360-410 kg) range resulting in exceptional performance.
          the awd system is unique in this weght class and allows the use of high power turbocharged engines of over 300 hp. in this configuration the car can have over 700 hp/ton power to weight ratio and still be able to put the power to the ground.
          vtnc
          esse veiculo é uma fabrica de orgasmos
            pqp
            o carrinho é praticamente um kart 4x4
              pqp
              na verdade ele é um kart carenado. so que 4x4
                coisa_triste
                o dp1 é mais insano..
                with an innovative awd system, extreme light weight and 1,000 hp per metric ton the dp1 is the flagship of the palatov motorsport product lineup. the dp1 is designed to use the [hartley v8](hartley v8)exclusively. a 4-cylinder prototype has been built and tested and has already received significant media attention worldwide.
                the production v8 version will push the boundaries of what a modern vehicle is capable of and is intended for very skilled and experienced track drivers who can make use of its immense potential. the dp1 will only be sold as a complete (turnkey) car exclusively for track use with no streetable option.
                http://www.palatov.com/cars/dp1.html
