  4. Fiat linea
Fiat linea
59 Posts 25 Posters 7.9k Visualizações 1 Watching
  • 3 Offline
    3 Offline
    347
    _fiat linea is an all-new segment c three-box saloon which dábuts at the istanbul motor show taking place from 2 to 12 november. produced in collaboration with tofas, the turkish joint venture between fiat auto and ko? holding quoted on the istanbul stock exchange, the fiat linea will be first manufactured in the joint venture?s bursa plant in turkey (at an annual production of 60,000 units) and marketed in a number of european and non-european countries starting in the second half of 2007. the vehicle will later be produced in other countries by fiat.
    designed by the fiat style centre, the new fiat linea presents an elegant, dynamic external line. the same stylistic attention has been paid to the interior, the lines of which are harmonious and well balanced with the exterior to create a bright and friendly environment capable of guaranteeing extraordinary interior roominess and superior comfort in terms of ergonomics and space available to the driver and passengers. this impression is confirmed by the car?s generous dimensions which set it at the very top of its segment: 4.56 metres long, 1.73 m wide, 1.5 m tall and with a wheelbase of 2.6 m, in addition to having a luggage compartment boasting an impressive 500 litres.
    an elegantly functional car, with a strong italian imprint, the fiat linea will be marketed in different equipment levels and equipped with features more usually found in higher segment vehicles as demonstrated by a number of sophisticated infotelematic devices which improve the comfort and quality of time spent on board.
    the fiat linea?s generous equipment is dedicated to the protection of driver and passengers and the customer can choose from a wide range of gasoline and diesel engines that combine excellent performance, low fuel consumption and absolute respect for the environment, coupled to both manual and automatic transmissions.
    and in order to guarantee the best price/content ratio, the various combinations of fiat linea equipment levels available are all characterised by high value for money._
    puta que pariu, se investirem direito nesse carro..
    abraços.
      maurício
      tbm gostei… esse farol do punto é phodastico...
        AIRpower
        muito bonito. a linha do teto (da coluna b em diante) lembra os audi.
          Fiasa Power
          new croma ?
          que não me venham mais com five-techs da vida … de resto , podem manter o padrão que vai ser um sucesso .
          abraços .
          • H Offline
            H Offline
            HaUcK33
            novo vectra com rodas ralo de pia, ok?
            de visual, esses carros novos da fiast não me convencem muito
              elcio.jr
              bonito bonito, so tem que ver a motorizacao nao dando uma de gm e montanu um monzao ja ta bom…...
                guabiroba
                finalmente foi lançado
                http://carsale.uol.com.br/noticias/ed101not9867.shtml
                  a fiat chutou bundas… pqp. o carr oficou d+
                  muito mais pics aqui:
                  http://www.fiatpress.com.br/fiatpresssite/….aspx?codigo=35
                  ah se eu tivesse com grana…
                    streit
                    r$60.900,00
                    achei muito caro por se tratar de um punto sedan.
                    pelo mesmo valor, vc pega carros de um segmento acima.
                      JF
                      http://carros.uol.com.br/ultnot/2008/09/17/ult634u3193.jhtm
                      linea 1.9 16v flex - r$ 60.900
                      linea 1.9 16v flex dualogic - r$ 63.900
                      linea 1.9 16v flex absolute - r$ 68.640
                      linea t-jet 1.4 turbo a gasolina - r$ 78.900
                      nesse site acima tem muita informação e fotos…
                        eu quero um tjet… tks.
                          Shark
                          na boa, achei muito bonito e com essas versões (todas boas ao meu ver) é bem mais fácil de agradar cada tipo de cliente.
                          bem completo os carros e de motorização nem precisa comentar. esse motor 1.9 deve ser uma beleza. quantos ao preço e os concorrentes diretos: tá na mesma faixa de preço dos concorrentes como focus, vectra, civic, corolla, c4 pallas e sentra. de alguns até mais barato o que aumenta mais ainda a briga.
                          a briga vai ser boa no segmento. pior pra vw que tá cada vez mais perdendo terreno e vendo suas vendas se concentrarem somente no gol g4 e g5.
                          não acredito que o novo voyage vá brigar com o linea, não vai vir com motor bom nem com tantos iténs de série deste nível. o polo, juntando os dois modelos, está na 28ª colocação dos mais vendidos.
                            guabiroba
                            r$60.900,00
                            também achei muito caro pra ser um preço de entrada. o focus que é de categoria superior, tem motor mais potente e suspensão mais evoluida custa menos. mas parece que ficou um excelente carro.
                              M5_E34
                              seda pequeno com preco de medio.
                              mas bonitao e bons motores…
                                gabriel
                                o comprimento dele é maior que o new civic.
                                  meus comentários:
                                  • pra mim o único defeito foram os mostradores de fusca. só os do t-jet que eu gostei.
                                  • o carro não é um punto sedan… ele entrou pra substituir o marea... coisa que acredito que irá fazer muito bem. ainda porque esse 1.9 aí promete
                                    VictorArrabal
                                    tive oportunidade de ver o carro e os motores…
                                    o carro em si é lindo, acabamento no nível do preço
                                    o motor 1.9 é gigante e muito imponente...parece que vai aguentar bem má-criações o 1.4 parece um motor de brinquedo, não dá para acreditar quão pequeno ele é...assim como a turbina...sinceramente o motor passa uma idéia de fragilidade muito grande, mas vamos ver né...as vezes me engano...
                                      r$60.900,00
                                      concordo com vcs…pra mim a versão mais básica viria custando de 50k a 55k
                                      meus comentários:
                                      o linea é um punto sedã que veio pra substituir o marea
                                        streit
                                        deve ser do tamanho do logan, e ai?
                                        o carro tem muitas qualidades, mas acho que a fiat ta posicionando ele alto demais.
                                          muito caro e sem nada demais que me chame a atencao….
                                          no....thanks....
                                          ps: cade o modafocka do abel ???
