2007 caterham x330 concept
**hahahaha…. pra comemorar os 50 anos do carro, colocaram um supercharged no motor 2.3 ford duratec...com isso ele gera 330hp e 30,[email protected], conta tb com câmbio de 6 marchas manual. o carro pesa 700kg
vi no texto que querem fazer um com bioethanol, será que vai rolar um caterham a alcool??
to celebrate its 50th anniversary, caterham unveiled its most powerful seven ever; the x330 é a one-off supercharged model boasting a mind-boggling power-to-weight ratio of 600 bhp per ton. the stealthy, matt black concept is based around the range-topping csr superlight, but the addition of a supercharger to the four-cylinder 2.3-liter ford duratec engine increases power massively from 260 to 330 bhp é as the name suggests. that means the x330?s equivalent power-to-weight ratio puts it ahead of the bugatti veyron (521 bhp per ton) and the mclaren f1 (559 bhp).
the near 35% power hike is achieved by a rotrex c30-94 supercharger, which provides a boost characteristic that rises linearly with engine speed. in other words, although the x330?s punch is greater at higher revs and speed, low-speed driveability isn t compromised thanks to an exceptional torque curve with over 221 lb-ft from 5500 to 7500rpm é 20 lb-ft more than the csr260.
as the x330 is an engineering test bed, it is envisaged that some of the concepts will eventually find their way into production. to begin with the x330 will spearhead the british firmês r&d into bioethanol power in the coming months as it seeks to assess the viability of alternative fuel sources in road and race applications and cement a further 50 years of history for the legendary seven.
in keeping with the seven ethos of ?adding lightness?, the extremity of the x330 doesn?t stop at moving parts. lighter gauge steel is used in the trellis-style chassis and the use of new lightweight wheels together with an abundant use of carbon fiber for the bodywork all adds to the stealth appearance of this perfect 50th birthday present.
esse é top …
abraços**
esse torque a gente consegue c ap aspirado
só que 30 kgf de torque num brinquedo leve desse… imagine como deve ser tenso...
mto legal esse mp lafer
deve ser um pouco divertido andar com isso.
não tem nem o que falar do lotus seven…
pior que tem um em brasília se não me engano, um csr 260. é carro que bate mclaren f1, enzo, carrera gt e cia num circuito.
mas no caso desse x330, não gosto da idéia de um compressor num carro como esse.
? o carro perfeito para receber um aspirado de baixa cilindrada e hi-rev.
