  4. Caterham - rst-v8
Caterham - rst-v8
13 Posts 9 Posters 2.7k Visualizações 1 Watching
    Dark_GT
    press release
    caterham announces official performance arm: powerhouse v8 engine delivers 1,000 plus bhp-per-tonne
    for those wanting an expression of british sportscar exclusivity, caterham cars has joined forces with rs performance to offer the ultimate in bespoke seven coachbuilding. caterham has long been the epitome of personalised motoring with almost every version of the 12,000 sevens on the road differing from one another. the joint venture takes that famous philosophy to an altogether new level.
    rs performance is an exclusive, niche engineering house. born out of the passion and pedigree of its founder, russell savory, it will offer an ?everything is possible? service to caterham customers wanting cars truly ?built to order?.
    using the motorsport-honed caterham chassis and benchmark technology as a cosmetic and engineering base, rs performance, will ?turn imagination into reality,? says savory.
    the heartbeat of every rs-monikered seven will be the unique rst-v8 engine. with more than 16 years of development behind it by russell savory, the 40-valve, 2.4 litre engine reliably delivers an incredible 400bhp in normally aspirated mode, or over 500bhp as a supercharged varient, whilst weighing only 90kg in full running gear.
    the unbridled lightness of the rst-v8 matched to the already featherweight seven chassis delivers a power-to-weight ratio of over 1000bhp per tonne é more than double of a bugatti veyron. this unique partnership will be open to customers looking for the ultimate in exclusivity, and carry a price tag to reflect the tailoring, detail and hand-built craftsmanship that will go into every rs-badged caterham.
    validation of the engineering house?s abilities comes in the form of the supercharged ?levante?. this is the first seven to rollout of rs performance?s hertfordshire doors and which only seven more of this type will be available.
    with a 12 week waiting time and costing over ?115,000, this supercharged engineering masterpiece boasts a modern interpretation of the seven?s classic looks with a sophisticated electronics package with traction and launch control to help get the phenomenal power to the floor. weight reduction runs throughout the car, from the carbon fibre interior finished with kevlar seats down to the hosing used on the cooling systems
    the rs performance badge will sit alongside the established, and soon to be expanded, ford powered caterham seven range.
    ?caterham and russell savory have a long history, and this seemed a natural progression of that relationship and shared engineering philosophy,? explained ansar ali, caterham cars managing director.
    rs performance rst-v8 engine technical specification
    configuration 90? v8
    capacity 2.4 litre
    valves 40
    construction aluminium main frame with dry sump
    max power 380 bhp @10,000rpm / 500+bhp @ 10,000rpm (supercharged)
    max torque 190 lbsft @ 8500rpm / 300 lbsft@ 8500rpm (supercharged)
    gearbox 6-speed
    overall length 45.6mm
    overall width 45.6mm
    height 48mm
    weight 90kg
    service intervals 8000 miles (minor) / 30,000 miles (major service & belt change)
    rs performance ?levante? technical specification
    price ?115,000 (dependent on specification)
    chassis caterham sv
    engine 2.4-litre, 40-valve rst-v8 supercharged
    max power 500+bhp @ 10,000rpm
    max torque 300 lbsft @ 8500rpm
    supercharge boost 0.8 psi
    gearbox 6-speed sequential, paddle shift option
    transmission lsd
    0-60mph (claimed) less than 3 seconds
    top speed 150mph (limited)
    wheelbase 2305mm
    overall length 3530mm
    overall width 1685mm
    height 1140mm
    weight from 520kgs
    suspension de dion rear, nitron 3-way adjustable shocks all corners
    wheels image billet; front 8 x 15, rear 10 x 15
    tyres avon cr500; front 195/45-15, rear 245/40-15
    brakes hi spec; front 280mm vented, rear 260mm.
    exhaust system btb 2 x 4-2-1 rear exit
    dashboard farringdon and spa design
    driver aids traction control, launch control
    additional two day driver training course provided on delivery of vehicle
      :p :hauhau: :) :)
      relação peso/potência assustadora
      tem gente aqui que vai infartar. :teteto:
        baralho :teteto:
        2.4 v8, 5 valvulas por cilindro, 10k rpm :hauhau:
          M5_E34
          pqp
            de 0 é velocidade borlesca em 5 segundos, no máximo :hauhau:
            depois dessa acho q vou precisar fazer umas 3 pontes de safena e 2 mam?rias pelo menos :hauhau: :infarto:
              baralho :hauhau:
              [snapback]676961[/snapback]
              desconfio q esteja errada esse informação
              ele usa 1 bloco especial feito p encaixar 2 jogos de cilindros e 2 cabeçotes de hayabusa
              ficaria v8 , 2.6 e 32 v
                [snapback]677304[/snapback]
                ga?cho, acho q esse motor q vc falou (usado na radical srt-8) é diferente desse do caterham…
                se vc procurar no g?glio vai ver que vêrias publicações colocaram esse mesmo motor 2.8 com 5v/cilindro como sendo o desse caterham novo...
                ali?s, esse motor pesa somente 90 kg...foda ao extremo
                  Mega
                  padawan de jaca.
                    padawan de jaca.
                    [snapback]677359[/snapback]
                    :hauhau:
                      Garcia
                      quando é que abre o leasing ? :hauhau:
                      muito fodastico
                      eu ia dizer pra alguém chamar o samu, mas não vai adiantar… :hauhau:
                        Maran
                        esquife.
                          muito fodastico
                          [snapback]677563[/snapback]
                          tem q chamar é o rabecão logo :hauhau:
                            morrer rulez :hauhau:
                            queria ver qual a final que um desses dá devidamente carenado.
