1973 toyota starlet
1973 toyota starlet
power n/a
under the hood 4ag 20-valve blacktop, hks adjustable cam gear, hks fine tune timing belt, 44mm individual throttle bodies, t3 velocity stacks, custom carbon fiber valve cover by danstoy, custom aluminum oil catch can by danstoy, custom stainless steel equal length, performance headers by danstoy, custom full stainless steel lower exhaust system by danstoy, ems stinger full stand alone ecu, custom aluminum radiator, custom aluminum coolant reservoir by danstoy, custom oil filter relocation kit by danstoy
driveline c s short shifter and engine modified by pass auto, gts rear end, trd limited slip differential, 4.7 gear ratio
rollers trd tosco 13x8.5 (front), trd tosco 13x9.0 (rear) with a032 yokohama tires
stoppers n/a
stiff stuff trd shocks with 6.5kg ae86 springs, trd shocks with yzz coilovers, cusco adjustable camber plates, cusco strut bar, install by pass auto
outside custom made metal fender flares made to fit trd wheels, 918 orange paint and body work by p.j. bonifacio autodesign, frp hood, cibie fog lamps custom mounted by danstoy, trd rear spoiler
inside trd racing bucket seats
http://www.superstreetonline.com/featuredv…rive/index.html
isso sim eh carro
melhor doq akelas bostas q enchem 0,3 e faz tchiiii
me lembrou o chevette hatch, o trueno brasileiro
imagina um chevas hatch com um c20xe do naipe desse motor toyota desse carrinho, x-tudo, com rodas 13x9 do mesmo jeito
[snapback]681874[/snapback]
no dia que eu ver um chevas nesse nipe eu sento e choro
