Micro megasquirt…
link
https://www.protocar.net/catalog/product_in…;products_id=37
para quem manja de ingles…
the expected release date for the microsquirt will be august 2007
as we approach the release date we will open a pre-order to ensure that you can get your hands on a microsquirt as soon as they become available
microsquirt is basically the same as the megasquirt-ii/ v3 main board, with the main difference in the injector drivers, map sensor, and connectors (the vr circuit is also different).
1. the fuel injector drives will max out at 5 amps each, enough to drive one low-impedance (or 4 high-impedance) injector per bank. to get everything to fit without lots of heat sinking, microsquirt uses the st vnd5n07 from stmicroelectronics to drive the injectors. this is not a peak and hold driver, but it does clamp the current at 5 amps, so it can be used with one low-impedance injector per bank, however the close time may be a tad higher (or you can use resistors). for up to 4 high-impedance injectors per bank, it should work fine. for example, for motorcycle use microsquirt will be perfect
2. in order to shrink the footprint of microsquirt, the map sensor was left off the board. an external map sensor, such as those from general motors products, can be used instead. see the microsquirt hardware page for more information on map sensors.
3. the board will also use the 35-pin ampseal connector and a sealed case to make a fully sealed unit. amazingly, the board is the physical size of a business card - connector and all. microsquirt s board size, including the 35-pin ampseal connector, is very small - 2.4 x 3.5 (61mm x 89mm), just slightly bigger than a credit card.
the bootloader is externally accessible, so there s no need to open the case, even to load new code. and the serial rs-232 signals come out of the ampseal connector (instead of a db-9 on the front, as with megasquirt). the board is sealed in a weather proof enclosure.
product information used from www.microsquirt.info
o ricardo do forum deve manjar..
ele jah mandou varias da normal..
tb pensei mt em trazer uma dessas, mas o ricardo aqui do forum na epoca me falou q não eh mt boa… (se comparando com a ms normal)
o preço eh bem legal, e se não me engano tem um cara aqui no br q tem tudo pra montar ela... ci´s, placas e demais componentes... depois procuro o link...
no brasil tambem temos a minims, que tem todas as funcões da ms 2.0 como controle de ignição, combustivel, comando varialvel, etc… o preço ainda é bem acessível, sendo qeu a pouco tempo atrás estava 380 reais, agora esta 420 desmontada.
opa, manda poara mim também o contato dele. o meu é chedid2@msn.com
o nome do cara acho que é armando, o email é o do site mesmo que eu me comuniquei com ele:
mega squirt brasil [megasquirtbr@megasquirtbr.com].
ele disse que fazia 550 com ela ja montada e testada.
vc está falando a v3.0 com processador ii? isso. ele é cara do site né? sabe se ele parcela em vezes no cartão?
eu mandei duas mensagem pro site e nada, e isso faz uns dois dias já… mandei novamente para o -e-mail, tomara que ele responda heheehe valeu desde já
ela é melhor que ft, dificilmente achará uma ie mais completa que a ms. como desvantegem (e grande desvantagem) está na assistencia técnica, que é via forum e comunidades no geral.
olha, eu vou mandar vir do eua a mega ii com a placa v3.0 desmotada, o kit usta 245 doletas, vou pedir mais 3 trasistores de iginiçao junto (controlar 3 bobinas) 8 doletas cada…. vai sair bem em conta eu mesmo monto. não vejo problemas de montar, se alguém precisa basta me pedir que eu monto. assistencia não é necessário, porém vc precisa conhecer como tudo funciona. não sou especialista em iee mas achei bem simples a instalação, se for necessário alterar alguma coisa para funsções específicas, tem tudo no site, tudo.... nada complicado. só precisa ler uma 3 vezes os manuais....
realmente a ms é mais para entusiastas, é cheia de detalhes sutis que para alguém totalmente leigo fica complicado montar e instalar corretamente.
eu montei algumas e já tenho certa experiência com o negócio. em breve meu carro ficará pronto e poderei testar com calma.
em comparação as outras do mercado, é de longe a mais completa e barata. não é perfreita, mas é muito divertida e eficiente. custo benefício insuperável.
sou eu mesmo quem faço a placa e monto os componentes. quem tiver uma ms e estiver enfrentando dificuldades, pode entrar em contato comigo. desde a parte de montagem/conserto da placa até a parte de ajuste.
abraços.
abraços.
streit, você faz a placa e monta ela com componentes comprados aqui mesmo no br, ou importa algo?
