  3. Fotos e Vídeos
  4. 2009 porsche 911 gt3 rsr
13 Posts 12 Posters 998 Visualizações 1 Watching
    Shark
    nessa nova versão de corrida o motor 6cc boxer passou de 3.8 pra 4.0 e conta agora com 450hp@7800rpm - redline em 9000rpm
    **[source: porsche]
    technical description porsche gt3 rsr (2009)
    engine:
    water-cooled, six-cylinder boxer engine; four valves
    per cylinder; dry sump lubrication; individual throttle
    butterflies; fuel injection; air restrictors 2 x 29.5 mm.
    bore:
    102.7 mm
    stroke:
    80.4 mm
    capacity:
    3,996 cc
    power output:
    331 kw (450 bhp) at 7,800 rpm
    max. torque:
    430 nm at 7,250 rpm
    max. revs:
    9,400 rpm
    transmission:
    six-speed gearbox with sequential jaw-type shift;
    oil/water heat exchanger; single-mass flywheel;
    hydraulic disengagement lever; three-plate carbon-fibre
    clutch; rear wheel drive; limited-slip differential 45/65%.
    body:
    monocoque body (basis gt3 rs) of hot-galvanised steel;
    aerodynamically optimised front end with front spoiler;
    aerodynamically optimised front underfloor; adjustable
    rear wing; 90-litre safety fuel tank with fast filling function;
    air jack; welded-in safety cage; bucket-type racing seat
    (on driver's side only) with flame-resistant seat cover;
    six-point seat belt adapted for use of the hans
    head and neck support; electric fire-extinguishing system.
    suspension:
    front:
    mcpherson spring strut axle; sachs four-way gas
    pressure dampers; double coil springs (main and ancillary
    spring); front axle arms adjustable for camber; adjustable
    sword-type anti-roll bar on both sides; power steering.
    rear:
    multi-arm axle with rigidly mounted axle sub-frame;
    sachs four-way gas pressure dampers; double coil springs
    (main and auxiliary spring); rear axle tie-bar reinforced
    and infinitely adjustable; adjustable sword-type anti-roll
    bar on both sides.
    complete suspension infinitely adjustable (height,
    camber, track).
    brakes:
    brake system with balance bar control.
    front:
    single-piece six-piston aluminium fixed callipers;
    inner-vented, 380 mm in diameter; racing brake pads.
    rear: single-piece four-piston aluminium fixed callipers;
    inner-vented, 355 mm in diameter; racing brake pads.
    wheels:
    front:
    three-piece bbs light-alloy wheels (11j x 18-34);
    central bolt;
    rear:
    three-piece bbs light-alloy wheels (13j x 18-12.5);
    central bolt.
    electrical system:
    motec display with integrated data recording; multi-function
    display with integrated gearshift indicator; adjustable
    traction control; battery: 12 volt, 50 ah, 140 ah alternator.
    weight:
    approx. 1,220 kg complying with a.c.o. regulations,
    1,245 kg complying with fia regulations.
    price:
    €380,000**
    fotos dele já na pista
    :hauhau:
      fusquinha do mau :hauhau:
        porsche. there is no substitute.
        dr. porsche ficaria orgulhoso.
          M5_E34
          :hauhau:
            LeonardoZ
            380k euros :hauhau:
              ahahahahahahahahahahahahaahahahahhahahahahaha
              fusquinha foi foda :hauhau:
                maurício
                porsche rulez….
                  daniel
                  estes porsches correm na alms (america le mans) e na rolex sport car series ???
                    M5_E34
                    pra alms eh esse ai, pra grand-am, eh um gt3 cup.
                      Mega
                      isso sim e um video game
                        PrEsA
                        uia
                        fortin, hein?
                          danielparati
                          eh manooo 340 mil euros vc acho caro kkk
                          a ferrari430 2008 gt3 saem por coisa de 300 mil euros
                          a 2009 quem vem com cilindrada aumentada para 4.5 antes 4.3 mais taxa e comandos novos novo sistema de cambio f1 e mais algumas coisas que não me lembro agoraa
                          ao este pra fazer este up a kessel racing emoresa que faz a transformção nas ferraris para gt3 pediu 250mil euros pqp os caras são doidos…....
                          outro carro megaa caro inviavel pelo custo e o aston martin
                          edgar mello comentou que custava coisade 430mil librassss kkkk
                          sem noção
                          ahhhh que fuscão ein
                          pqp :positivo:
                            jorgeaugustov8
                            caraiooooooooo show de bola .
