  3. Fotos e Vídeos
  4. 300 cvs de rua x 300 cvs wrc…..................
32 Posts 16 Posters 3.3k Visualizações 1 Watching
    que do caralho vc tem mais dados de outros carros do rallycross?
    [snapback]621405[/snapback]
    sou do psa man?acos e lá a galera só posta de citroen e peugeot :ninja:
    vai + 1 mamão aí :olhos:
    in 1993 jean luc pailler and citroen developed a xantia turbo 4x4 to replace his successful bx turbo 4x4 which he had driven in the european and french rallycross championships. this car had evolved through the years and will be driven by jean luc until at least the year 2000. he won the european championship with the xantia in 1993 and became french champion in 1993, 1994 and 1995 and has subsequently won even more races.
    at the start, while still driving a bx, a white xantia was used having been resprayed completely blood-red. the engine the team fitted was the superb bx 1905cc 16valve turbo delivering a staggering 550hp. the power was upped to 650hp in 1997 and nearly 700hp in 1999. by that time, the cubic capacity had been increased to 1998cc. in the 1999 season the car received a new paint-job - yellow and blue.
    not only the engine changed through the years, also the car s appearance. the body became wider and wider and the air/cooling inlets larger and larger. the hydropneumatic suspension parts are specially made for jean luc in a special citroen factory in asnieres.
    a major change toke place in 1995. the car had changed its appearance but lost 50kg in total weight. this was a big achievement because the engine was enlarged to 1998cc which was heavier then the older 1905cc version. the suspension was changed too.. and also the complete hydropneumatic system. they removed the high-pressure pump, accumulator and reservoir system to lower the weight.
    just before the start of the race an external pump is connected to the hydro-system of the car (a small handy device on wheels). then the required height of the car is set (front and back independantly) and the system is closed. all the spheres have a special extra connection on top which can be used to regulate the gas-pressure. for the power steering a small high-pressure pump is fitted.
    in 1999 in addition to jean luc pailler another frenchman gilles stievenart also is also driving a xantia turbo 4x4. during the european championship rallycross race 1999 in faleyras, france he finished in 8th position (startnumber 17) while jean luc pailler ended as winner overall (startnumber 8).
    beneath some photos of the xantia, most of them showing the earlier version in 1994 but giving a lot of technical details of the car. click on the photo s and you will see them in a larger scale.
      HaUcK33
      :olhos:
        Mega
        1.9 turbo rlz.
          :olhos:
          [snapback]621457[/snapback]
          imagine uma versão desse xantia (barca luxuosa) 4x4 c esses 700 cvs na rua :ninja:
          350 já tava bom :ninja:
            HaUcK33
            700cv na rua… morrer rlz
              Blackout
              caralho anda demais
                [snapback]621493[/snapback]
                nao eles compararam um subaru de rua com o de pista…
                  transeunte
                  mais um comparativo: subaru wrc vs. subaru sti - na pista:
                  http://www.youtube.com/watch?v=dxrdle2ghi0
                    [snapback]621907[/snapback]
                    adorei o vêdeo
                      Edu4rdoBR
                      pisco o z?io o trem já nos 100…
                      :todoido:
                        HaUcK33
                        [snapback]621799[/snapback]
                        ahn?
