  3. Fotos e Vídeos
  4. Can-am series
Can-am series
38 Posts 12 Posters 2.2k Visualizações 1 Watching
    http://br.youtube.com/watch?v=fjr0aqrlgy4
    isso não é carro de circuito, é dragster :sppt:
      uop shadow avs mki chevy…
      george follmer devia ter seis bolas, pra guiar um kart shifter de 740 bhp desses :pix:
      sério, olhem o tamanho desse carro
      engine
      engine  chevrolet 90? v 8
      engine location  mid , longitudinally mounted
      configuration  aluminum block and head
      displacement  8.095 liter / 494 cu in
      bore / stroke  112.8 mm (4.4 in) / 101.6 mm (4 in)
      valvetrain  2 valves / cylinder, ohv
      fuel feed  fuel injection
      aspiration  naturally aspirated
      drivetrain
      chassis/body  fiberglass body on anodized aluminum monocoque
      front suspension  double wishbones, coil springs, friction dampers, anti-roll bar
      rear suspension  double wishbones, coil springs, friction dampers, anti-roll bar
      steering  rack-and-pinion
      brakes  vented discs, all-round, rear inboard
      gearbox  hewland lg500 4 speed manual
      drive  rear wheel drive
      dimensions
      wheelbase / track (fr/r)  2184 mm (86 in) / n/a / n/a
      performance figures
      power  **740 bhp / 552 kw @ 6400 rpm **
      torque  **888 nm / 655 ft lbs @ 5600 rpm **
      bhp/liter 91 bhp / liter
      tudo isso, em 1970…  :o_o:
      [snapback]660655[/snapback]
      isso não é um carro, é um kart com um motor chevy v8 bruto
      isso é o q eu chamo de ser um piloto macho, pqp
      isso não é carro de circuito, é dragster   :pix:
      [snapback]660696[/snapback]
      :sppt:
      posta as fotos das mclaren, tio :(
        mclaren m8fp
        olha a largura do pneu traseiro…
        engine
        configuration aluminum alloy block and head
        fuel feed lucas fuel injection
        drivetrain
        chassis/body aluminum monocoque
        front suspension double wishobes, coil springs, shock absorbers
        rear suspension double wishobes, coil springs, shock absorbers
        gearbox hewland lg500 ii 4 speed manual
        dimensions
        weight 700 kilo / 1543.2 lbs
        wheelbase / track (fr/r) 2464 mm (97 in) / 1524 mm (60 in) / 1494 mm (58.8 in)
        performance figures
        **power 740 bhp / 552 kw @ 6400 rpm
        torque 888 nm / 655 ft lbs @ 5600 rpm
        power to weight ratio 1.06 bhp / kg**
        mclaren m8e/d
        bruce mclaren perdeu a vida num monstro desses… :sppt:
        os mclaren dominaram a can am durante anos, só perdendo o posto de né1 para os turbo panzer porsche em 1973... dominaram de uma maneira tão acachapante a categoria, que acabaram por dar fim a ela... e graças tambem a crise do petróleo de 1973.
          posta o turbo panzer :sppt:
            l? vai banguela :(
            porsche 917/30 can am killer
            esse já é covardia…
            não dá nem pra brincar...
            engine
            engine 912.52 180? v 12
            configuration magnesium alloy block, aluminum alloy head
            displacement 5.374 liter / 327.9 cu in
            bore / stroke 90.0 mm (3.5 in) / 70.4 mm (2.8 in)
            compression ratio 6.5:1
            valvetrain 2 valves / cylinder, dohc
            fuel feed bosch fuel injection
            aspiration twin eberspacher turbos
            drivetrain
            chassis/body body on tubular frame
            front suspension double wishbones, coil springs, shock absorbers, anti roll bar
            rear suspension double wishbones, coil springs, shock absorbers, anti roll bar
            gearbox type 920 4 speed manual
            dimensions
            weight 849 kilo / 1871.7 lbs
            length / width / height 4560 mm (179.5 in) / 2100 mm (82.7 in) / 1080 mm (42.5 in)
            wheelbase / track (fr/r) 2500 mm (98.4 in) / 1668 mm (65.7 in) / 1564 mm (61.6 in)
            **performance figures
            power 1100 bhp / 821 kw @ 7800 rpm
            torque 1112 nm / 820 ft lbs @ 6400 rpm
            bhp/liter 205 bhp / liter
            power to weight ratio 1.3 bhp / kg
            top speed 386 km/h / 240 mph
            0-60 mph acceleration 2.1 s
            0-100 mph acceleration 3.9 s**
            0 a 160 km/h em 3.9 segundos… chega a ser bizarro
            a foto abaixo mostra donohue no dia de mais uma conquista in?dita. foi no dia 9 de agosto, dez dias antes do seu falecimento, ao volante do porsche 917/30 nos boxes do talladega superspeedway. contrário ao costumeiro visual azul-amarelo da sunoco, fiel patrocinador da penske, com o qual donohue foi campeão na can-am em 1973, a porsche aparece em vermelho e com logotipos do patrocinador cam2.
            a meta: o 917/30, chassi número 003 com motor 5.4 boxer 12 biturbo normalmente desenvolvendo 1100 hp, é colocado na pista para conquistar o recorde mundial de velocidade em circuito fechado. com pressão do turbo aumentada, assim rendendo cerca de 1500 hp, donohue atinge uma velocidade média de 355,78 km/h, a velocidade máxima nas retas chega a 382 km/h.
            como diria o fernando, 1 2 3 parei de brincar :o_o: :sppt:
              l? vai banguela :(
              esse já é covardia…
              engine
              drivetrain
              dimensions
              como diria o fernando, 1 2 3 parei de brincar   :pix: :sppt:
              [snapback]660703[/snapback]
              definitivamente, 1 2 3 parei de brincar
              vai se fuder 1,3 hp pra empurrar 1 kg de carro…
              detalhe...4 marchas eram mais do q suficientes :o_o:
                e tudo isso no fim dos anos 60, comeão dos 70… monstros...
                queria, só por curiosidade, comparar os tempos de volta desses carros em laguna seca com os carros da lms atuais... não duvido nada que os lms tomem toco :sppt:
                  esse carro em le mans acho q tinha capacidade pra varar os 400 km/h com um po nas costas
                    RedSun
                    fico imaginando se resolvem abrir uma categoria sem limites como essa nos dias de hoje…
                      [snapback]660710[/snapback]
                      fiquei curioso e fui procurar…
                      1-dindo capello/allan mcnish 1:11.175 (113.197 mph) (pole desse ano na lmp1)
                      1- mark donohue porsche 917/30 tc 0:57,374 (pole de 73 na can am)
                      alguém sabe se o tra?ado de laguna seca mudou alguma coisa nos ultimos 30 anos????
                      :( 14 segundos também é sacanagem
                        RedSun
                        year: distance (miles): record (time): record (speed): driver:
                        57- 85 1.9 0:52.926 129.237 mario andretti
                        86- 94 2.214 1:09.625 114.476 jacques villeneuve
                        96- 2.238 1:07.722 118.969 helio castroneves
                        retirado do site do circuito
                          ou seja, o circuito cresceu 0,338 milhas = 500 e poucos metros…
                          bom, acho q 500 e poucos metros, a diferença de tempo ainda assim seria suficiente pro porsche ganhar a disputa :sppt:
                            http://www.superspeedway.com.br/noticias/n….aspou_log=8805
                            http://www.classicscars.com/wspr/results/c…/canam1973.html
                            procurei os recordes de volta no site do autódromo e não achei nada…
                              [snapback]660733[/snapback]
                              mas o que diabos o mario andretti usou pra cravar um tempo de 52,9??? um helic?ptero?
                                [snapback]660738[/snapback]
                                a pergunta é pertinente…
                                o mark donohue cravou 57s baixo em treinos...ele só pode ter usado um f1 pra cravar esse tempo....
                                  [snapback]660740[/snapback]
                                  acho que devia ser um f-5000, um f-1 não conseguiria virar tão baixo…
                                    tentei editar mas não deu…
                                    • um f-1 da época...
                                    já descobri que o recorde é de 82, falta o carro... mas tá achando que devia ser um frisbee , um f-5000 com as rodas carenadas, muito comum na can am da época...
                                      pora tudo
                                      esses tro?os são coisa linda de deus. esse mundinho politicamente correto de carrinhos de câmbio no volante, asr, tcs, abs e etc é um saco…
                                        Vitinhu_Pinho
                                        tem uns que parecem carrinho de autorama quase nem andam neh..
                                        qdo sair o dvd vou querer um..
                                          Schucht
                                          os carros parecem um titanic. com as cornetas pra cima. :hauhau:
                                          corrida de verdade.
                                          loucura
