  3. Fotos e Vídeos
  4. Can-am series
Can-am series
38 Posts 12 Posters 2.4k Visualizações 1 Watching
    mclaren m8fp
    olha a largura do pneu traseiro…
    engine
    engine chevrolet 90? v 8
    engine location mid , longitudinally mounted
    configuration aluminum alloy block and head
    displacement 8.095 liter / 494 cu in
    bore / stroke 112.8 mm (4.4 in) / 101.6 mm (4 in)
    valvetrain 2 valves / cylinder, ohv
    fuel feed lucas fuel injection
    aspiration naturally aspirated
    drivetrain
    chassis/body aluminum monocoque
    front suspension double wishobes, coil springs, shock absorbers
    rear suspension double wishobes, coil springs, shock absorbers
    steering rack-and-pinion
    brakes vented discs, all-round
    gearbox hewland lg500 ii 4 speed manual
    drive rear wheel drive
    dimensions
    weight 700 kilo / 1543.2 lbs
    wheelbase / track (fr/r) 2464 mm (97 in) / 1524 mm (60 in) / 1494 mm (58.8 in)
    performance figures
    **power 740 bhp / 552 kw @ 6400 rpm
    torque 888 nm / 655 ft lbs @ 5600 rpm
    bhp/liter 91 bhp / liter
    power to weight ratio 1.06 bhp / kg**
    mclaren m8e/d
    bruce mclaren perdeu a vida num monstro desses… :sppt:
    os mclaren dominaram a can am durante anos, só perdendo o posto de né1 para os turbo panzer porsche em 1973... dominaram de uma maneira tão acachapante a categoria, que acabaram por dar fim a ela... e graças tambem a crise do petróleo de 1973.
      posta o turbo panzer :sppt:
        l? vai banguela :(
        porsche 917/30 can am killer
        esse já é covardia…
        não dá nem pra brincar...
        engine
        engine 912.52 180? v 12
        configuration magnesium alloy block, aluminum alloy head
        displacement 5.374 liter / 327.9 cu in
        bore / stroke 90.0 mm (3.5 in) / 70.4 mm (2.8 in)
        compression ratio 6.5:1
        valvetrain 2 valves / cylinder, dohc
        fuel feed bosch fuel injection
        aspiration twin eberspacher turbos
        drivetrain
        chassis/body body on tubular frame
        front suspension double wishbones, coil springs, shock absorbers, anti roll bar
        rear suspension double wishbones, coil springs, shock absorbers, anti roll bar
        gearbox type 920 4 speed manual
        dimensions
        weight 849 kilo / 1871.7 lbs
        length / width / height 4560 mm (179.5 in) / 2100 mm (82.7 in) / 1080 mm (42.5 in)
        wheelbase / track (fr/r) 2500 mm (98.4 in) / 1668 mm (65.7 in) / 1564 mm (61.6 in)
        **performance figures
        power 1100 bhp / 821 kw @ 7800 rpm
        torque 1112 nm / 820 ft lbs @ 6400 rpm
        bhp/liter 205 bhp / liter
        power to weight ratio 1.3 bhp / kg
        top speed 386 km/h / 240 mph
        0-60 mph acceleration 2.1 s
        0-100 mph acceleration 3.9 s**
        0 a 160 km/h em 3.9 segundos… chega a ser bizarro
        a foto abaixo mostra donohue no dia de mais uma conquista in?dita. foi no dia 9 de agosto, dez dias antes do seu falecimento, ao volante do porsche 917/30 nos boxes do talladega superspeedway. contrário ao costumeiro visual azul-amarelo da sunoco, fiel patrocinador da penske, com o qual donohue foi campeão na can-am em 1973, a porsche aparece em vermelho e com logotipos do patrocinador cam2.
        a meta: o 917/30, chassi número 003 com motor 5.4 boxer 12 biturbo normalmente desenvolvendo 1100 hp, é colocado na pista para conquistar o recorde mundial de velocidade em circuito fechado. com pressão do turbo aumentada, assim rendendo cerca de 1500 hp, donohue atinge uma velocidade média de 355,78 km/h, a velocidade máxima nas retas chega a 382 km/h.
        como diria o fernando, 1 2 3 parei de brincar :o_o: :sppt:
          l? vai banguela :(
          esse já é covardia…
          engine
          drivetrain
          dimensions
          como diria o fernando, 1 2 3 parei de brincar   :pix: :sppt:
          [snapback]660703[/snapback]
          definitivamente, 1 2 3 parei de brincar
          vai se fuder 1,3 hp pra empurrar 1 kg de carro…
          detalhe...4 marchas eram mais do q suficientes :o_o:
            e tudo isso no fim dos anos 60, comeão dos 70… monstros...
            queria, só por curiosidade, comparar os tempos de volta desses carros em laguna seca com os carros da lms atuais... não duvido nada que os lms tomem toco :sppt:
              esse carro em le mans acho q tinha capacidade pra varar os 400 km/h com um po nas costas
                RedSun
                fico imaginando se resolvem abrir uma categoria sem limites como essa nos dias de hoje…
                  [snapback]660710[/snapback]
                  fiquei curioso e fui procurar…
                  1-dindo capello/allan mcnish 1:11.175 (113.197 mph) (pole desse ano na lmp1)
                  1- mark donohue porsche 917/30 tc 0:57,374 (pole de 73 na can am)
                  alguém sabe se o tra?ado de laguna seca mudou alguma coisa nos ultimos 30 anos????
                  :( 14 segundos também é sacanagem
                    RedSun
                    year: distance (miles): record (time): record (speed): driver:
                    57- 85 1.9 0:52.926 129.237 mario andretti
                    86- 94 2.214 1:09.625 114.476 jacques villeneuve
                    96- 2.238 1:07.722 118.969 helio castroneves
                    retirado do site do circuito
                      ou seja, o circuito cresceu 0,338 milhas = 500 e poucos metros…
                      bom, acho q 500 e poucos metros, a diferença de tempo ainda assim seria suficiente pro porsche ganhar a disputa :sppt:
                        http://www.superspeedway.com.br/noticias/n….aspou_log=8805
                        http://www.classicscars.com/wspr/results/c…/canam1973.html
                        procurei os recordes de volta no site do autódromo e não achei nada…
                          [snapback]660733[/snapback]
                          mas o que diabos o mario andretti usou pra cravar um tempo de 52,9??? um helic?ptero?
                            [snapback]660738[/snapback]
                            a pergunta é pertinente…
                            o mark donohue cravou 57s baixo em treinos...ele só pode ter usado um f1 pra cravar esse tempo....
                              [snapback]660740[/snapback]
                              acho que devia ser um f-5000, um f-1 não conseguiria virar tão baixo…
                                tentei editar mas não deu…
                                • um f-1 da época...
                                já descobri que o recorde é de 82, falta o carro... mas tá achando que devia ser um frisbee , um f-5000 com as rodas carenadas, muito comum na can am da época...
                                  pora tudo
                                  esses tro?os são coisa linda de deus. esse mundinho politicamente correto de carrinhos de câmbio no volante, asr, tcs, abs e etc é um saco…
                                    Vitinhu_Pinho
                                    tem uns que parecem carrinho de autorama quase nem andam neh..
                                    qdo sair o dvd vou querer um..
                                      Schucht
                                      os carros parecem um titanic. com as cornetas pra cima. :hauhau:
                                      corrida de verdade.
                                      loucura
                                        PrEsA
                                        rapaiz
                                        que coisa insana
                                        alguem tem este dvd no seu tubo???
                                          Zungalele
                                          the group 7 category was essentially a formule libre for sports cars; the regulations were minimal and permitted unlimited engine sizes (and allowed turbocharging and supercharging), virtually unrestricted aerodynamics, and were as close as any major international racing series ever got to anything goes.
                                          … were frequently faster around laps of circuits used by both series than their contemporary formula 1 cars.
                                          absurdo
                                          o pior é que cada carro era mais bonito que o outro.
