  4. Polinho…
Polinho…
19 Posts 14 Posters 2.7k Visualizações 1 Watching
    Mega
    basic vehicle: vw polo mki
    engine: vw 1.8l 16v (turbo by ame)
    power: 1047ps/770kw 950nm at 7734rpm with 2.75bar boost
    820ps at 2.1bar boost
    1/4mile test so far driven with 2.1bar boost and 820hp 9.42s/245km/h
    acceleration perfromance with 2.1bar boost
    0-100km/h (62mph) 2.7s
    0-200km/h (125mph) 7.0s
    0-245km/h (153mph) 9.42s
    shift rpm 9400rpm
    topspeed 6.gear at 9000rpm over 300km/h
    6speed tranny from audi tt with quattro awd and awd lock
    8 fuel injectors 650ccm at 3bar
    adjustable fuel pressure up to 4.2bar
    garret gt 40 rs turbo
    exhust mainfold with push charge (dont know the correct word for stoßaufladung)
    ame high performance piston roads with improved connections 160mm
    ame forged pistons 82.5mm
    crankshaft 86.4mm lift
    alu oil sump
    improved cyl head with stronger valve springs and fixed overhead bucket tappet
    different camshafts for intake and exhust valves
    special build intake mainfold
    alu 4 stage air intake system simmilar to rally sport used or the one that audi used in the us imsa race series
    free programmable cpu with ame motronik 2.65
    exhust system handbuild 76mm
    intercooler water air
    water methanol injection
    clutch sachs rs2 sinta flywheel from vw g60
    coiloverkit suspension
    street tires 16 with 205/55 tires
    race tires 15 rims with avon slicks
    weight including driver under 900kg(1980lbs)
    video: http://www.vox.de/am_videovoting?p=v&id=309
      Mega
      ah…
      detalhe...
      anda na rua.
      ^_^
        shimi
        show, rsrs
        tem bico injetor pra caramba ai heim…
          pô mega…....pelo seus padrôes achei que ia ser um carro beeeemmmm mais bonito...... êta ratoeirinha horrenda :confuso:
          ps: mas com + 1000cv eu dou um desconto..... :teteto:
            vwfan
            eu vi 12 bicos… estou errado?
              147 4x4 é :confuso:
                BRUTaL DLX
                caralho
                ainda não tinah visto 1.8 com tanta força.
                  tem metade da fabrica da marelli ali?
                    PrEsA
                    a minha sonda é igual à dele, kkk :teteto:
                    o resultado… umas quatro vezes menos :hauhau: :olhos: :copa:
                    e sinceramente eu não faria igual não... prefiro cores escuras :confuso: :teteto: :teteto:
                    pergunta... o pessoal ponteiro daqui com os fuscas e pneus drag estão virando tempos parecidos??
                    e a transmissão do tt está aguentando bem, né? mesmo o carro sendo bem leve ela deve ser muito parruda
                      brunin
                      não sei se entendi bem, mas são 8 bicos no coletor (na foto somente 4 estão ligados) + 4 bicos injetando água + metanol no cooler???
                      tem foto dele com as 16 pra rodar na rua???
                        brunin
                        não deu tempo de editar, mas são bielas de 160mm??????????
                          Marcel_16V
                          rapaz… achei meio alto 9.42s
                          mas que brutaria, heim.
                            milTT
                            uma dúvida: como é esse esquema que ele usou pra prender o escape na carcaça quente? é só juntar os dois e pôr essa abraçadeira (chamam de abraçadeira de tucho)? já vi uns carros aqui no brasil com esse esquema na pressurização e fiquei intrigado..
                              jizuis
                              curti a ratoeirinha. dá pra brincar até. :ohoh:
                                Violator
                                uma duvida… essa gt 40 rs é roletada?
                                axo que se andar com uma pressão maior ele entra na casa dos 8s
                                  Mega
                                  pô mega…....pelo seus padrôes achei que ia ser um carro beeeemmmm mais bonito...... êta ratoeirinha horrenda :piti:
                                  ps: mas com + 1000cv eu dou um desconto..... :piti:
                                  e ce acha q eu achei isso bonito ?
                                  so no cofre.
                                  aosuhdouas
                                  a minha sonda é igual à dele, kkk :piti:
                                  o resultado… umas quatro vezes menos :piti: :piti: :piti:
                                  e sinceramente eu não faria igual não... prefiro cores escuras :ohoh: :cry: ;)
                                  o carro do sapinho fez 9.5, so com as patas de frente.
                                  roletada.
                                    Violator
                                    se ela é roletada, aquilo entre as duas carcaças não seria um aeroquip de oleo?
                                      Violator
                                      pergunto isso por poura leiguice mesmo…as roletadas tem a liubrificação da mesma forma que as normais?
                                        JF
                                        tb achei feio que doi, mas o motor o salvou…. :parede:
