  4. Pistão usinado para receber biela forjada
90 Posts 14 Posters 23.0k Visualizações 1 Watching
    guabiroba
    valeu menegotto, pesquisei as bielas do t-jet, realmente são bem mais resitentes que a do 1.4 8v, porém tem o comprimento centro à centro menor. as do t-jet (mesma dimensão das usados no abarth europeu)tem 128,50 e do 8v 129,35. a mesma info sobre o tamanho dessas bielas foi passada pela técnica da autorizada ventuno aqui de sp.
    http://wossneronline.../fiatconrod.php
    abs e obrigado. vou procurar um bom torneiro para trabalhar os pistões
    esse link que postou não seria do sevel turbo?
      Freddy
      acho que sim…mas olha o preço das forjadas chinesas no atacado:
      dear mr. fredy,
      thanks for your inquiry we are your honest supplier from china.
      our company specializes in manufacturing high performance connecting rods for aftermarket racing applications for more than 14 years.
      for 40pieces fiat 1.4l conrods, the price is 25usd/piece for h-beam and 26usd/piece for i-beam without bolts, we can supply our own made bolts(the same quality as arp8740 bolts), the price is 1usd/bolt.
      the shipping cost is 300usd for 40pieces conrods shipping to brazil, são paulo city by dhl(door to door), shipping time is 3-5days.
      our production time is 35days for conrods.
      please check the dimensions:
      applications pcs/set center to center big end bore pin diameter big end width pin end width bolt size
      fiat uno / punto / tipo 1.4l turbo 4 128.5   48.64   22   25.425   25.425   3/8 -24
      we hope sincerely to become your reliable supplier and enjoy your business. welcome to write to us for any questions. we look forward to hearing from you.
      thank you & best regards
      zick huang(sales manager)
      mobile: +86-18674833488
      e-mail: [email protected]
        Freddy
        dear mr. fredy,
        …esse kit u$ 4.500,00 (haja dinheiro..) deve ficar muito bom em um t-jet já que é preparado exatamente para ele vira, pistões. bielas...e veja o que dizem: our kit is good for 1500bhp and 12000rpm
        http://www.pureperformancemotorsport.com/shop/product_info.phpoproducts_id=429
          Freddy
          dear mr. fredy,
          desculpe, não sei afirmar com certeza se eo kit acima serve no t-jet…serão para o sevel? enfim essa foi a resposta do vendedor (que talvez esteja só vendendo e desconhece 100% a aplicação):
          hallo fredy,
          yes our rods are suitable for your engine
          we have them in stock so if you want them please let us know,
          looking forward to your reply,
          best regards
          thomas faska (director)
          pure performance motorsport p/l
          factory 11/2 quist crt
          dandenong south
          vic 3175
          melbourne
          australia
          ph +613 9792 5868
          fax +613 9792 5868
          mob +61 (0) 438 800 507
          email [email protected]
          web: www.ppmracing.com
            Freddy
            pode fazer esse serviço sim tranquilo, nos gm que usam pino travado nas bielas, o pessoal quando meche jah altera pra usar deslizante. pra turbo tem que ser assim…
            só cuida quem vai fazer o serviço... tem que ser de mta precisão
            caso ainda não tenha comprado as bielas da sufran, dá uma pesquisada no conjunto do motor t-jet.... pistão e biela dele seguram fácil esses 1,2 bar
            http://wossneronline.com/fiatconrod.php
            sem querer abusar, caso alguém conhecer um torneiro de confiança que já fez tal serviço e puder indicar, ficaria grato (como comentou o menegotto, ao que parece muitos proprietários de turbinados gm famailia 1 adotaram essa técnica)
            obrigado.
              Pellegrino
              cara, se todo dono de carro turbo fosse criterioso que nem vc…
                Freddy
                bem, depois posta umas fotos e impressões do punto turbinado, fiquei curioso, deve ter ficado fino de andar…
                olá pellegrino,
                segue o carro com as bielas originais e 1,0 kg. depois que colocar as bielas forjadas postarei as impressoões.
                abs, freddy
                [vídeo punto 1.4 8v turbo](vídeo punto 1.4 8v turbo)
                caso alguém tenha interesse, o carro foi preparado na auto power glide no broolin, próximo à berrine. trabalham bastante em ap e chevettes com essa motorização. o proprietário se chama joão, tel.81027789 (não sei da oficina agora) [email protected]
                  Ricardo-UT
                  cara, não sei se é só em algumas versoes , mas acbei de fazer um motor fire 1.0 2004 e não tinha trava de pino no pistao, era dezlizante tambem e o motor era original ainda
                    Freddy
                    então, como comentei no início do tópico, os 1.0 fire tem trava. levarei um pistão igual ao seu para servir como modelo para a cava pois usarei as mesmas travas que você usa no 1.0. seu carro ficou bom? está alimentando o motor de que forma?
                    abs, fredy
                      Ricardo-UT
                      o carro ta original e não era meu e sim de um cliente que o usa na sua empresa, estva com 350.000 km rodados e pra meu espanto ao abrir o motor o eixo estava perfeito sem um risco sequer , tanto que na retifica nao foi necessario retifica-lo , somente polimento e bronzinas novas eta motorzinho macho
                        Freddy
                        abs, fredy
                        vi que a metal leve fabrica com travas e sem travas vai entender.
                          Freddy
                          imagino que sim, rodando original o motor aguenta. creio que se não tivesse abusado, a biela iria suportar.a injeção original foi projetada para trabalhar com 3,5bar na linha de combustível, viajei para santa catarina (tinha sido a terceira vez e nunca deu problemas) e resolvi baixar a pressão da linha para economizar combustível. na ida baixei para 3,25 e foi super tranqüilo sempre a 100km/h. ficou muito econômico, fiz são paulo 600km com 38 litros de alcool. na volta baixei para 3,0 e e depois de 500km percorridos parei em um posto de estrada….combustível pra lá de batizado. na saída do posto tive que pisar fundo pois havia muitos carros e estava chovendo. nessa pisada a biela partiu e arrebentou sub-bloco e bloco. bom para aprender né manter sempre os 3,5 na linha. desmontando o motor estava tudo impecável, sem riscos, pistões, bronzinas ok, vira ok (mas com um furo enorme no bloco)...só a biela que não suportou mesmo.
                            Freddy
                            boa tarde à todos.
                            sou novo no forum, em primeiro lugar gostaria de saudar à todos que partcipam e contribuem com o mesmo.
                            gostaria de uma dica.
                            sou proprietário de um punto 1.4 8v. sempre andei com 0,9 de pressão positiva no coletor e nunca tive problemas mecânicos (rodei aprox.40.000km).
                            ao aumentar a pressão, 1.2bar percebi que as bielas não suportam.
                            encontrei um jogo de bielas forjadas usadas fabricadas pela sufran, 4340 c/parafusos arp (usa pino deslizante). alguém poderia me auxiliar? se usinar meu pistão original para encaixar travas de pino do fire 1.0 (só o fire 1.0 usa travas no pino, diferente do 1.4 que é fixo)e cortar a extremidade do pino para adaptar a biela que usa pinos deslizantes em meus pistões fire originais, há chances de ter esses pistões confiáveis?
                            abs,
                            fredy
                            será que eu poderia colocar buchas de teflon ao invés de usinar os pistões?
                            abs,
                            fredy
                              boa tarde à todos.
                              abs,
                              fredy
                              abs,
                              fredy
                              olá, vi que o tópico se iniciou em 2008, ja chegou a fazer a mudança?
                              as bielas do t-jet tem o mesmo comprimento que dos 1.4. esse punto turbo que voce está usando como base (1990 - 1997) nao é motor t-jet…
                              no t-jet o bloco foi aumentado em 0,8mm pra ajustar a taxa, enquanto a biela tem o mesmo comprimento (deve ser pra nao sacrificar mais a r/l)
                              montei pistoes e bielas do t-jet no meu 1.3 16v, baixando a taxa pra 8,5:1 devido ao pistao ser pra um motor 1.4 (altura de compressao menor assim como montar pistoes 2.0 e vira 1.8 nos ap)
                              sobre usinar o pistao pra receber as travas, seria mais indicado colocar pistoes iapel forjados, ja sao de trava e tem taxa menor se usando bielas do t-jet. os pistoes originais tambem nao aguentam grande coisa. se a biela forjada que vc arranjou for só mais curta, pode ser até bom se baixar a taxa um pouco se for usar pistoes originais, mas nao pode baixar muito...
                                Freddy
                                como vai lost..tb lembro dos seus posts. obrigado. você tem razão, o 1.4 europeu (1990-1997 em questão nada tem haver com as do grand punto 1.4 t-jet)seu carro está legal com o conjunto do t-jetá quanto às bielas adquiridas tem o mesmo comprimento das do 1.4 8v orginal, ou seja 129,35 mm (sufran), dessa forma usando os pistões originais (por questão de $)não vai mudar o r/l assim como não vai destaxar. bem que gostaria de colocar as iapel. penso em não abusar por enquanto e quando for colocar os pistões trocar a injeção suplementar por injeção mais adequada na própria flauta.
                                valeu
                                  valeu
                                  tudo bem, e você?
                                  o motor ficou perfeito, não percebi qualquer perda no torque em funcao dos 8,5:1 de taxa de compressão. ainda não estou usando o carro no dia a dia pois ainda nao fiz o controlar. andei com ele apenas 130km até agora. por isso, estou andando com apenas 0,6 de pressão. só vou aumentar a pressão depois de passar dos 1000km rodados. mesmo com 0,6 o carro anda muito bem, deve ter em torno de 180hp o que é muito bom em funcao do tamanho do motor e potencia original.
                                  pense nos pistões forjados, pois os pistoes dos motores fire são relativamente frágeis por serem motores de concepção moderna (pistoes e bielas leves). a iapel tem pistoes pra fire 8v.
                                  apenas por curiosidade, qual o valor das bielas forjadas?
                                  injeção eletrônica programável? eu conheço uma que é espetacular :d http://www.fuelbox.com.br/
                                  segue foto dos conjuntos originais e do t-jet lado a lado para comparação. o da direita é do t-jet.
                                    Freddy
                                    valeu
                                    tudo bem, e você?
                                    muito bom lost vou ler mais sobre o fuel box abs
                                      Freddy
                                      oi lost, ficou por r$ 1690,00. mas veja as novas na sufran:
                                      bielas especiais para competição
                                      -construídas em aço forjado sae 4340
                                      -perfil i , preparação forte/turbo/nitro
                                      -perfil h , preparação leve/aspirado
                                      -temperadas e revenidas
                                      -acabamento final com shot-penning
                                      -pino de pistão flutuante
                                      -dimensões conforme necessidade - modelo/perfil/entre-centros/diâm. do pino, etç.
                                      -com parafusos arp 2000 - 5/16 ou 3/8
                                      já fabricamos bielas para motor fiat fire, mas precisamos que nos forneça algumas informações.
                                      valor
                                      jogo de 4 peças r$ 1.790,00
                                      condições de pagamento: 50% no pedido, saldo na entrega
                                      prazo de entrega: 90 dias
                                      estamos com muitos pedidos em carteira, e a produção é pequena, quase artesanal, só fabricamos bielas especiais.
                                      em anexo, ficha para preenchimento, informando as medidas, e algumas fotos, meramente ilustrativas, de bielas especiais produzidas.
                                      bom final de semana, e bom carnaval.teremos expediente normal, para atender pedidos atrasados.
                                      obrigado,
                                      foto do material sufran e comparativo visual entre as bielas fire 1.4 8v original e as feitas sob medida na sufran
                                      abs, fredy
                                        valor
                                        obrigado,
                                        abs, fredy
                                        muito caras :d
                                        nao consegui ver as fotos… tenta hospedar em outro lugar, nao ta abrindo nao... queria ver :p
                                          Freddy
                                          valor
                                          obrigado,
                                          abs, fredy
                                          muito caras :d
                                          desculpe pelas fotos. sseguem novamente:
                                          fot enviada pela sufran:
                                          comparativo visual entre as bielas originais e forjadas sufran:
                                          abs,
