  3. Fotos e Vídeos
  4. John shepherd, eclipse
20 Posts 13 Posters 2.5k Visualizações
    daniel
    o carro parece ser stock de estrutura, nao me referindo a pneus pneus
    ele espanca até big block nos videos
    http://www.youtube.com/watch?v=atjj-yamdsk
    http://www.youtube.com/watch?v=xxk2iaomtb0
    neste aqui o honda ainda sai na frente
    http://www.youtube.com/watch?v=_eiuctk4rqa
    7sec
    http://www.youtube.com/watch?v=twnzbcexude…related&search=
    empolgação do narrador
    http://www.youtube.com/watch?v=aw04qvhe0ms
    só lembrando que ele esta quase checando no tempo do ybl que tem acho que uns 2000hps a mais
      esse é fera
      290 km/h no final dos 402…....................
        e ouvi dizer que o pellegrini pediu um motor desse do usa pro eclipse dele.
          daniel
          [snapback]606539[/snapback]
          ? aquele um que estava em montagem que ira correr na pro mod ??
            esse carro tem tração 4x4. verdadeiro dragão mesmo…
              Mega
              paguei pau.
                [snapback]606541[/snapback]
                sim…esse mesmo
                  daniel
                  sim…esse mesmo
                  [snapback]606702[/snapback]
                  queria ver ele dando coro no ybl
                    daniel
                    chassis & interior
                    factory unibody chassis
                    autometer gauges
                    all steel except for hood and hatch
                    gary reese 7.49 certified cage
                    momo steering wheel
                    kirkey seat
                    jic coilover suspension
                    the brake man front and rear brakes
                    volk 15x7 bronze te-37 wheels
                    mickey thompson et drag tires
                    engine
                    buschur racing 2.0l short block
                    je pistons
                    groden aluminum rods
                    eagle 4340 crankshaft
                    hard block filled block
                    stock oil pump and pan
                    fox lake power products cylinder head
                    race port intake and exhaust
                    1mm ferrea intake valves
                    1mm ferrea exhaust valves
                    ferrea dual valve spring
                    o-ringed deck
                    custom grind crane cams
                    unorthodox cam gears
                    ams vsr intake manifold with 90mm throttle body
                    fuel, ignition, & engine management
                    buschur racing dual fuel rails
                    10 x 1600 cc injectors
                    methanol fuel
                    3 gallon fuel cell
                    waterman mechanical fuel pump
                    aem engine management
                    aem wideband kit
                    aem injector driver box
                    msd dis 2 ignition box
                    buschur racing coil on plug coils
                    16v turbostart battery
                    nitrous express nitrous system jetted for 100 hp
                    drivetrain
                    sheptrans.com dog box transmission
                    act carbon clutch
                    the driveshaft shop aluminum driveshaft
                    the driveshaft shop transfer case upgrade
                    the driveshaft shop stage 5 front axles
                    turbo & exhaust
                    forced performance 321 stainless header
                    tial blow off valves
                    tial 44mm wastegate
                    forced performance gt42r turbo
                    ams 3.5 upper pipe
                    forced performance 3.5 side exit exhaust
                    hallman boost controller set to 55 psi
                      4cil 2000cc????
                      ta loko
                      babei
                        55 psi
                        :putz:
                          3.85 bar…
                          mermao, isso é tempo/velocidade do degreas...
                          mais o cara tem 2 cil. a menos de 1/3 da cilindrada pqp
                          quem disse que no have replacement for displacement? :putz:
                            FabioRR
                            esse da? segue o lema:
                            quem tem medo de pressão, é art?ria entupida
                              gabriel
                              pqp sem palavras…
                                Le
                                carrao mesmo
                                lembro dele quebrando o cambio na final da nopi de 2005
                                voou pedaão pra tudo quanto é lado.
                                  BRUTaL DLX
                                  du caralho este
                                    Bruno Ramos
                                    nossa, animal demais esse eclipse…
                                    gagina ele alinhando com o ybl e com a ss-10 do alexandre...
                                      turbocahrger is the best replacement for displacement.
                                        Mega
                                        segundo me consta, esse carro é 2.7 lts.
                                          fraco… fraco nao ... raquitico
