  4. Qual melhor? gtech ou o apexi?
13 Posts 7 Posters 1.8k Visualizações 1 Watching
    DRoP
    bom a apexi tambem tem um aparelho tipo o gtech e tal, q te da varias informações do carro, gostaria de saber dos amigos, qual o melhor dos 2, e por q..?
      drop se nao me engano o apexi vc compra aquele que parece um vafc, e ainda por cima tem q comprar um g-meter(acelerometro) deles….
        vai de gtech que eu aprovo pq já usei e muita gente daqui tbm aprova.
          DRoP
          o negocio é q o apexi custa 100 dollares a menos ;)
          pelo que vi lá não lembro de precisar nada não…
          saca só
          the new rev/speed meter gp is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine rpm, and elapsed times. however, the strength of the new unit lies in its differences. probably the most obvious being its completely redesigned look. this new aesthetically pleasing model was crafted to match the likes of other highly popular a pex electronics such as the vafc (vtec controller) and the avcr (boost controller). the new screen utilizes the easy to read vfd (vacuum fluorescent display) with built in light sensor used in many of a pex s line up.
          the new unit also delivers a host of new functions. standard features include: engine rpm, vehicle speed, travel distance, and battery voltage (all which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), peak hold, replay (with 60 second playback.), speed limiter cut, 0-100m, 200m, 400m times with trap speed, 0-100km/h, 200km/h, 300km/h times, 100km/h, 200km/h, 300km/h ?e0 times, user defined mid range acceleration, stop watch functions, best time memory, rpm warning, speed warning, rpm and speed outputs (for external devices requiring an rpm or speed signal.), tire size correction (for acceleration and timing accuracy.), and vehicle weight input.
          one of the most exiting of the new features is the option to utilize the revolutionary a pex g-sensor (sold separately). the g sensor allows the unit to measure g forces in 4-way front/rear/left/right directions. this data can be plotted in a graph display to map acceleration characteristics and lateral g s on the race track, or used in an array of new features including: highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, horsepower calculation, and loss power calculation. by taking advantage of the optional g sensor, the user can produce extremely accurate acceleration measurements. usually, when measuring acceleration times using the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. using the g sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times.
          concept:
          multifunction monitoring and timing device
          characteristics:
          variety of functions such as tach, speed, 0-400m time, etc?ein one unit.
          g-tech
          ? esse gtech pro parece ser mais foda, ele grava as informações e da pra passar pro pc, sinistro heheheheh
            tem tbm um da autometer q saiu:
            mais infos:
            http://www.autometer.com/cat_gauge_dpic.aspx
              mais infos:
              [snapback]320361[/snapback]
              esse é tipo o gtech pro mais simples q tinha antes e foi descontinuado…
              o apexi é bom, mas o gtech pro rr (sei lá qual o modelo...hehehe) é fodastico....armazena logs, rola de passar esses logs pro pc e talz....pelo q eu vi o apexi não faz isso...
                Extreme Fast
                sou louco por akele apexi que é boost controller tb.
                  [snapback]319943[/snapback]
                  sabe ler?
                    e deve ser uma bica esse sensorzinho…
                    certeza q deve ser mais caro q akele gtech mais simplezinho, dos numeros vermelhos...
                      ou q esse autometer q postaram aqui…
                        gostei desse da autometer por ficar (parece) embutido no painel. os gtech são show (tenho um gtech pro) mas facilmente são confundidos como anti-radar =(
                          nossa, dei uma olhada por cima no ebay e vi esse autometer na media dos 180 dollares…
                            DRoP
                            entre um apexi e um g-tech ss, o mais simples q nao passa os logs pro pc, qual seria mais interessante? o preco é muito parecido, coisa de 15 dollares +- eu acho..
