  4. Preparação barata
Preparação barata
101 Posts 23 Posters 11.5k Visualizações 1 Watching
    LoartVeiguer
    ol? phil..
    pq vc disse que o hemi é um motor chato pra caralho? e 425 cavalos láquidosó tem certeza? brutal hein
      LoartVeiguer
      720hp, carburador 1095 cfm king demon
      price: $12,895.89
      ficha técnica:
      engineered by gm performance parts and gm racing exclusively for sportsman racers, the new zz572/720r is built around an all-new gen vi tall deck bow tie cylinder block. this all new race block is filled with a forged 4340 steel crank with 4.375 inch stroke, shot peened forged 4340 hbeam rods, and forged aluminum pistons with full floating wrist pins. plasma moly piston rings are standard is the screened and louvered windage tray. gm’s first purpose built drag race engine is filled with hard core race parts for hard core performance and long term durability.
      the redesigned rectangular port aluminum cylinder heads result in a race gas only 12 to 1 compression ratio. a solid roller cam with 0.714 inch lift actuates the stainless steel valves. and, of course, hardened chromemoly retainers, roller rocker arms, and dual valve springs are used to complete the valve train.
      a new gm tall deck single plane intake manifold and 1095 cfm king demon carburetor deliver enough air and fuel to make the 720 horsepower at 6250 rpm and 685 ft.lbs. of torque at 4500 rpm. ignition is handled by a multiple spark discharge ignition. and an sfi approved torsional damper is installed at the factory. out of the crate and into your race car – it’s just that simple.
      race gas fueled, high revving horsepower, all from gm, the zz572/720r is the engine that will get you down the track consistently, pass after pass, season after season.
      available in both short block, long block and deluxe engine configurations
        Inssurection
        a foto do charger q vc postou eh linda
        esse charger que vc postou eh lindo
        pena nunca ter sido fabricado no brasil pq se tivesse um desses aki eu ia ateh começar a dar o * pra comprar ele
          LoartVeiguer
          acho que é unanimidade.. o carro é lindo.
            JESUS
            ae phil mais eh verdade q existe um motor dodge charger r/t q tinha 440cv de fabrica??
            olha, tinha uns hemi 426 com coletores cross-ram que eram utilizados por funcion?rios da chrysler na dácada de 60
            essa desgra?a aí é um magnum 440 com virabrequim de 4,25 polegadas de curso, a cilindrada subiu pra 487 polegadas (quase 8 litros)
            carro de rua pra usar todos os dias, fazia 1/4 de milha em 10,6 segundos, era o carro de rua mais forte da dácada de 60/70
              JESUS
              bom….
              tenho um vizinho que tem um maverick v8... com um 302 dentro do capo...
              na época q o real valia mais q o dálar, ele importou um coletor edelbrock torker e um hadrijet holley (num lembro se é de 650 ou 750 cfm)... e num tenho certeza se tem comando de válvulas mais nervoso...
              mas sei que o carro com esse pouco de alterações dá 220km/h no painel... só não vai mais porque a bomba de gasolina mecânica num consegue alimentar mais.
              quanto aos toyota vvti autom?tico.... já levei alguns qdo eu tinnha o 206 1.0 16v... o câmbio autom?tico deles num aproveita mto bem akele motor dahora... pelo menos pra arrancar em sinal num aproveitou.
              ei phil... vc tem umas coisas do arco da velha aí, hein???
              []s a todos [/quote]
              os maverick gt quadrijets saiam das concession?rias ford com essa configuração: comando iskenderian 270 + coletor edlebrock + quadrijet holley + tuchos mecânicos e molas de válvulas duplas
              particularmente eu acho o ford 302 um motorzinho vagabundo, mas tem que goste, é um motor girador, mas dá crepe demais
                JESUS
                ol? phil..
                pq o hemi é um motor de competição, coisa pra pista, precisa de manutenção mais frequente e cuidados, etc…
                o magnum 440 não... vc pode usar ele 40 anos sem sequer regular a folga de válvulas (até pq os tuchos eram hidr?ulicos)
                  JESUS
                  aqui no abc paulista tem o charger 76 do andré carrillo, preparado pelo isaque, o dodgeiro mais maluco do estaleiro do riacho grande
                  312 cavalos nas rodas (390 cavalos no motor), cabeçotes trabalhados, balancins regul?veis, válvulas maiores molas de maior carga, comando de válvulas mopar performance de 324 graus, coletor de admissão edelbrock torker 2, quadrijet 750 cfm emulsionando metanol, bobina mallory promaster, distribuidor msd, cabos de vela msd, módulo msd 6al, velas ngk mais frias e coletores 4x1 paulinho.
                  vejam a cara de alegria do isaque:
                  anda bem o bichinho viu...
                    REDSUNS
                    esse ae q vc postou eu vi uma arrancada dele em um video, pra mim q era mais forte.
                    mas ja esse magnum ae nao deve achar pra vender nem a pau, uma coisa dessa no brasil eh rara :casaderepouso:
                      Maverick-MG
                      caros amigos….
                      sou um feliz proprietario de um ford maverick gt, que ainda naum roda pq esta na restauração mas breve estará nas ruas...
                      andei no maveco de um amigo preparador, o mesmo que vai preparar o motor do meu carro e posso dizer com certeza...
                      o carro é muito gostoso de andar na rua... o carro dele tem quadijet pequena (650cfm), comando 272 (se naum me engano,), admissão performer rpm e escape dimensionado....
                      o carro tem ainda uns truques sujos tipo volante aliviado, vira balanceado e etc....além da suspenção e freios melhores.
                      o carro pra andar na rua num tem igual....liso, gostoso, torcudo, e se rapar o po, lixa mesmo
                      o acelerador é crespo e o motor gira que é uma beleza
                      acredito que o maverick v8 original tome pau de a3, civic e etc....
                      agora....com um certo investimento como esse feito na carro do meu amigo (que é o mesmo que farei no meu carro) e que é relativamente barato, o maveco encara qq carro de igual pra igual apesar da idade.
                      aos que estão com vontade de comprar um muscle, eu recomendo
                      esse meu amigo tem mais um maveco, alem desse que andei ,com 4 weber 48 ida e um par de cabeçote de aluminio, alem de 2 opalas, um turbo e um aspirado, ambos muito bem feitos e vou lhes dizer um negocio:
                      naum gosto de opala( ja tive, prefiro maverick), mas um opala com um comandinho e uma carburação weber e um escape dimensionado...............diversão garantida
                      abraão a todos
                        maverick é show mesmo concordo em ser diversão garantida .
                          ah com certeza… qualquer um destes v8 mais antigos só com uma boa carburação já vem muito cv... com comando e mais ajustezinhos aí libera tudo o que a fabrica escondia .
                          mas eu particularmente não gosto de mavecko, já tive e não gostei do carro em só... prefiro puma gtb/amv :hauhau:
                            Maverick-MG
                            na verdade, o maverick tem um serio problema de freio (facilmente resolvivel)…
                            na época em que saiu, morria muita gente.
                            umas buchas mais rigidas na suspenção tb são bem vindas..... fora isso, é só a parte de motor e cair na estrada....
                            pura diversão
                            não tenho muito tesão em dodge apesar de achar alguns muito bonitos... prefiro os ford... acho que tem mais cara de esportivo, mesmo com mecanica não tão forte quanto alguns crysler....
                            sonho de consumo: ford gt 40....simplismente o mais lindo de todos os ford ja feitos.
                              streit
                              :hauhau: :ppteam:
