  4. Influ?ncia da temp. do combustável
63 Posts 17 Posters 4.1k Visualizações 1 Watching
    RodrigoLóke
    typically, the water is mixed with methanol to improve its cooling effect. mixtures up to 50% work well
    50% - 50 % ??? :p :)
      eu só naum entendo…sempre soube que lá fora eles usam injeção de água pra resfriar e evidar detonação....justamente em carros turbinados............
      water injection
      water injection is useful in preventing detonation in supercharged engines that produce more than about ~10 psi of boost. the water injection system is a completely separate system from the fuel injection system.
      typically, the water is mixed with methanol to improve its cooling effect. mixtures up to 50% work well. amazingly enough, regular windshield washer fluid works well, as long as you buy the blue stuff. if you can find one that says 50% methanol, 50% distilled water, that is great. or you can add methyl hydrate to your water.
      t
      o set-up a water injection system, you can use a fluid tank, small pump (windshield washer pumps work well), and a hobbs switchto inject fluid into the inlet tract. this switch closes at a specific pressure, and is installed in the intake manifold. one hobbs switch is napa part# 7011577. this corresponds to a hobbs part number #76052. it is a normally open 2 terminal switch, factory set to 15 psi. however it is adjustable from 14 psi to 24 psi. both lower and higher pressure rangesare available from hobbs 5000 series pressure switches.
      [snapback]507032[/snapback]
      esse sistema de agua na verdade é metade agua e metade metanol
      se injetar só agua não vai ter os efeitos vc tá pensando.
      agua no cilindro só serve pra aumentar a taxa (quanto+agua, mais taxa) e resfriar um pouco…......desde que bem pulverizada..............até pq se não for, o que vc vai ganhar é um belo calão hidr?ulico........... :p
        RodrigoLóke
        agua no cilindro só serve pra aumentar a taxa (quanto+agua, mais taxa) e resfriar um pouco…......desde que bem pulverizada..............até pq se não for, o que vc vai ganhar é um belo calão hidr?ulico........... :)
        [snapback]507144[/snapback]
        mesmo assim….50% - 50% é coisa pra ded?u......
        pra falar a verdade, não tenho mto a manha de fazer essas coisas não........coisa de maluko..... :p :)
