  3. Fotos e Vídeos
  4. Da série esportivos fora-de-série gringos
7 Posts 7 Posters 644 Visualizações 1 Watching
    Maran
    ficha técnica:
    price 225 500 gbp
    engine s62 bmw m5 v8 w/dry sump lubrication
    position mid longitudinal
    aspiration natural
    valvetrain 4 valves per cyl w/variable valve timing
    displacement 4941 cc / 301.5 cu in
    bore 94 mm / 3.7 in
    stroke 89 mm / 3.5 in
    power 387.8 kw / 520 bhp @ 7000 rpm
    specific output 105.24 bhp per litre
    bhp/weight 416.0 bhp per tonne
    torque 550 nm / 405.7 ft lbs @ 4500 rpm
    redline 7500
    body / frame carbon body over central carbon honeycomb monocoque w/tubular steel rear frame
    driven wheels rwd w/viscous slip differential
    front tires 235/35 x 19
    rear tires 305/30 x 19
    front brakes cross dilled & vented discs w/ap racing 6-piston calipers
    rear brakes cross dilled & vented discs w/ap racing 4-piston calipers
    steering power assisted steering
    f suspension double wishbones w/coil over dampers, anti-roll bar
    r suspension double wishbones w/coil over dampers, anti-roll bar
    weight 1250 kg / 2756 lbs
    wheelbase 2636 mm / 103.8 in
    front track 1569 mm / 61.8 in
    rear track 1480 mm / 58.3 in
    length 4300 mm / 169.3 in
    width 1852 mm / 72.9 in
    height 1138 mm / 44.8 in
    transmission 6-speed manual
    gear ratios 2.875:1, 1.773:1, 1.267:1, 1.000:1, 0.833:1, :1
    final drive 3.70:1
    top speed 321.9 kph / 200.0 mph
    0 - 60 mph 3.4 seconds
    em ação:
    <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/2cvkgtrser0"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/2cvkgtrser0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
    <center><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/s2zddvdulvu&amp;"><param name="wmode" value="transparent"><embed src="http://www.youtube.com/v/s2zddvdulvu&amp;" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></object></center>
      eu tenho um tg do kay zed one (adoro a pronúncia) e acho caro demais por ser uma salada de peças. mas é um carro legal.
        impressão minha ou o carro veio dentro de uma caixa ? :hauhau:
        obs: q marcha lenta maaaais linda….
          RodrigoLóke
          pra mim, qualquer carro que passe dos 100cv/litro aspirados, já é fora de série. lembra bastante a lotus, não?
            Mauricio Bozo
            bacana o carro… e os temposó
            honda s2000 2002
            1.997cc
            240cv @ 8.300rpm
            :hauhau:
            abracos
              M5_E34
              hehehe, eh uma carreta especifica, muito usado em classicos.
              vejo direto, porque todo dia passo na m20 bem perto de brands hatch.
                Carbon
                o legal é o clube que vem quando você compra um…
                vale tanto quanto o carro
