  4. Duratec turbo. alguem já fez ou já viu pronto?
219 Posts 33 Posters 55.5k Visualizações 1 Watching
    streit
    moçada, aproveitando o tópico, eu mandei ontem um email para a burton power questionando justamente sobre qual o limite seguro para se preparar um duratec. e a partir de quando eu preciso ir atrás de peças forjadas.
    a resposta foi uma aulinha muito bacana.
    hello luiz
    thank you for your email.
    the engine features an alloy block and head plus some clever
    technology straight from the race track. the crank sits up
    inside the block and is held in place and braced at the same
    time, with an aluminium girdle. oil drain galleries run down
    the side of the block directing the returning oil away from the
    crank thus not slowing it down.
    the crank is strong but the rods and pistons aren’t necessarily
    so. they owe their appearance to proper race items but in
    truth, the ultra-slim skirted pistons are cast rather than
    forged. the rods are a touch boxy although they’re svelte. the
    combination though results in a free-revving assembly ideal for
    controlling emissions – it spins up quickly thus negating the
    need to use up fuel doing so.
    unlike the zetec, the head has big ports and very large valves,
    again adding to its well-breathing/low emissions status.
    what this means to us is it doesn’t take much to tune the
    duratec to around 200bhp, at which point, you need to switch
    the rods and pistons to more reliable components. we already
    stock forged accralite pistons and h-section farndon steel rods
    for such conversions.
    to see increases from standard power however, it is necessary
    to perform an induction change, preferably to throttle bodies
    although a manifold is available for dcoe side-draughts. we
    list the weber alpha and omex throttle body kits as well as
    cosworth and titan throttle body assemblies which should cover
    most requirements for induction.
    the duratec is currently a very popular choice in kit cars,
    where it completely transforms the car into a reliable road
    rocket with the best modern engine combination. in this format
    though, it needs turning round to rear-wheel drive. like the
    components we offer for the zetec, we also do a full range for
    this engine too, including re-directing water manifolds, sumps
    and bellhousings to adapt the engine to a ford type rwd
    transmission – in standard form the unit doesn’t comply to the
    classic ford bolt pattern.
    we can also supply complete duratecs built by cosworth on the
    same assembly line as their formula 1 race engines. which kind
    of speaks for itself in terms of quality these are available
    in several levels of tune ranging from a 195bhp full engine to a
    300bhp unit.
    in addition, the cosworth range encompasses plenty of parts to
    get the best from the engine in whatever car it’s fitted to –
    whether that’s the standard front wheel drive layout, as in the
    focus, fiesta or mondeo, where a cosworth d-power inlet
    manifold really makes the best from the standard type induction.
    or, you can replace the lot with a roller barrel assembly,
    suitable for both front and rear wheel drive – it really does
    depend how much power you want, since there’s loads for the
    asking.
    an enormous cosworth range is now currently available for this
    engine, which practically guarantees the power output they
    quote. with the name to back it all up, you really can’t go
    wrong.
    if you’re looking for a futuristic engine this is it
    we would not go above 200 hp
    regards ian
      bate exatamente com o que foi dito aqui
        desculpe sobre as pernas de frango…........mas foi praticamente isso q falaram.
        200 cvs deve vir no máximo uns 22 de torque..............se conseguir 200 cvs no turbo, virá uns 30 de torque.........aí quebra.
          streit
          eta bando de chupa-cabra hein… :olhos:
          da próxima vez falem 6 números de 0 a 60 ok? :hauhau:
          mas enfim andré. compra um joguinho de biela e pistão e turbina pra gente ver. em matéria de chão e câmbio o focus é ótimo. talvez uns freios mais generosos tb.
          e eu ainda mandava vir uma valve cover da cosworth... :olhos:
            Da Luz Racing BR
            bielas forjadas 4340, modelo i-bean com parfusos para girar 9500 rpm. custa
            r$ 1.950,00
            jogo de pistão com pinos, travas de pinos e anés r$ 1.380,00
              an.guimaraes
              r$ 1.950,00
              legal
              ta mais ou menos nos preços de gm mesmo como vc falou. acho que vai dar certinho com as minhas intenções :hauhau:
              na verdade nao tava esperando que esse carro fosse assessivel para mexer, mas já que é assim, vou suspender a montagem do omega e partir para esse carrinho mesmo
              só faltou ser tração traseira mas nem tudo é prefeito
              obrigado
                Da Luz Racing BR
                o duratec é um otimo motor, venho a mais de 4 anos já buscando informações com nosos contatos na europa. a cada dia fico mais impressionado com este motor.
                adianto que com miolo forjado, um bom coletor de escape, admissão tambem, pois coletor de plastico não vai suportar, bem acertado em ignição e injeção com pressão relativamente baixa para os padrões nacionais, vai ter uma maquina de sorrisos.
                como todo motor moderno exige muito conhecimento tecnico e muita atenção em detalhes de montagem. sei de casos que perderam o motor por detalhes simples mesmo, e olha que o motor nem muito fuçado era.
                  Tio America
                  so para completar informação sobre o o aspirado que quebrou aqui no rio (que o anderson falou) aparentemente alguem alterou uma coisa na ft e o carro ficou com ponto de mais, coisa de 50 graus, o que aparentemente não deu muito certo.
                    ponto demais em 99% dos motores quebram as canaletas…...............nesse foi logo a biela.
                    eles deram diversas aceleradas no canal de s francisco.........e indo p autódromo
                    foi quebrar logo lá dentro.
                      é, queimei a língua.
                      mas enfim, esse motor é muito interessante.
                        Tio America
                        gaucho, pode ate ser que a informação que eles deram foi para encobrir outra coisa, não vou entrar no mérito disto, apenas estou repasando a verssão oficial que eles deram, de qualquer forma o que eles falaram foi que era um parâmetro de ajuste da ft, por exemplo podia ser para que se a temperatura da água chegar a 100 graus da mais 20 graus de ponto, coisa que ao andar de noite no canal não estava acontecendo.. sei la. pode ser tambem que quem fez esta alteração (obviamente alguem que não sabia o que estava fazendo) fez isto depois disto, ate mesmo no dia do evento.
                          poderia compartilhar com a gente esses detalhes, jack ? ?
                          :pix:
                            Padula
                            ah, mudando algumas poucas coisas, duratec é derivado do mzr…
                            http://en.wikipedia.org/wiki/mazda_mzr_engine
                            http://en.wikipedia.org/wiki/ford_duratec_engine#duratec_20
                              bom, eu fui um não-tão-inovador de montar um gm 2.0 16v turbo e esbarrei na embreagem, pois no caso dos gm o acionador é hidraulico, não podia por mta carga de plato pq estourava, então o meu patinava q era uma beleza. teria que passar pra mecanico, mas o carro era muito novo, eu usava no dia a dia e não quis algo tão radical. então acabei nem forjando, nem nada.
                              e com relação ao focus ai, teria esse problema também? como é o acionamento de embreagem dele? aguenta carga no plato? tem multidisco pra ele?
                              quais seriam as soluções que teriamos pra jogar essa potencia toda dentro do cambio?
                                an.guimaraes
                                então…
                                dá mais uns detalhes pra nós sobre suas pesquisas, até mesmo em termos de acertos de suspensão etc.... no meu caso acho que nos freios nao vou precisar mexer porque vem com abs, mas a suspensão eu gostaria de dar um ajuste legal. ja vi que existem amortecedores bilstein e kits eibach pro-sport (aqueles com barrras estabilizadoras etc...) para esse carro. será que você teria essas peças ou pelo menos o valor para encomendá-las?
                                agora, o que vc quis dizer com pressão relativamente baixa ?
                                seria alguma coisa perto do usado pela indústria nacional como 0,7 ou 0,8 como o golf gti?
                                tinha em mente de forjar e rodar com 1,0 ou 1,5 no pé com booster para 2,0. seria exagero?
                                ou seria menos pior rodar com 1,0 e um kit nitro de uns 100cvó
                                  até o astra flex (280mm) tem disco maior q o focus.
                                  precisa melhorar o freio e muiiiiiiiiiiiiiiiiiiiiiito.
                                    Milho
                                    o freio original do focus é uma bosta.
                                    experiência própria
                                      ftajiri
                                      o evandro lima tirou 185 cv e quase 24kg de torq com pico a quase 2500 rpm, de zetec 1.8… pistoes do 2.0, cabeçote stagei venom, escape original, coletor admissão venom e polias
                                      do duratec ele fez coletor admissao, escape, comandos polias, cabeçote stage2 ou 3.. forjadão taxadao. alcool .. 220cv e 25kg torq
                                      ambos aspro
                                        Da Luz Racing BR
                                        to meio ocupado aqui, mas logo coloco algumas info.
                                        peças de suspenção não trabalho.
                                        exclusivamente peças motor.
                                          como faz com a embreagem?
