  4. Coletores para carros turbo
124 Posts 22 Posters 21.4k Visualizações 1 Watching
    Tommy
    olhando o data sheet do carro, tudo eh impressionante….
    volvo t5 engine / underhood highlights
    • volvo 2.5-liter 5-cylinder turbocharged engine (standard 218 horsepower)
    • evolve custom turbo system (capable of over 500 horsepower)
    • evolve exhaust manifold
    • evolve turbo downpipe
    • evolve 3.5-inch exhaust system
    • evolve engine control management software
    • evolve cold air intake
    • evolve intake manifold
    • evolve coolant reservoir
    • evolve strut tower brace
    • garrett gt30r turbo by turbos.com
    • turbo wastegate, blow off valve and boost management by turbosmart
    • flex technologies silicone hoses
    • thermo tec heat protection
    • turbonetics intercooler
    transmission & driveline
    • volvo built 6-speed manual close-ratio transmission
    • haldex electronically controlled all-wheel-drive system with evolve/haldex performance software
    • volvo dynamic stability traction control (dstc)
    brakes
    • evolve big brake system
    o front: 380mm 2-piece rotors with 8-piston liquid cooled ap racing calipers
    o rear: 362mm 2-piece rotors with 6-piston ap racing calipers
    • evolve “e” slotted rotors
    • evolve braided stainless steel brake lines
    • volvo anti-lock braking system with electronic brake force distribution
    suspension
    • front:
    o evolve adjustable coil over suspension
    o evolve camber plates
    o evolve anti-roll bar
    o koni adjustable struts
    o eibach springs
    • rear:
    o evolve pushrod-activated rear suspension with inboard strut/spring assembly
    o evolve lower control arms
    o evolve toe-adjusters
    o evolve adjustable end links
    o adjustable struts
    o eibach springs
    wheels & tires
    • hre c21 3-piece alloy wheels
    o front:  19.0-inches x 9.0-inches
    o rear:  19.0-inches x 11.0 inches
    • pirelli pzero rosso tires
    o front:  255/30zr-19
    o rear:  305/25zr-19
    exterior
    • custom silver metallic/titanium gray metallic two tone paint scheme
    • evolve aerodynamic front bumper
    • evolve aerodynamic side sill spoilers
    • evolve aerodynamic rear bumper
    • evolve mesh grilles
    • evolve trunk spoiler
    • evolve tail light trim
    • evolve fender scoops
    • rear wheel wells lightly flared
    • darkened tail lamps
    • shaved fuel door with relocated filler
    • painted moon roof
    • laminated side windows
    • bi-xenon high intensity gas discharge headlamps
    interior
    • silver carbon fiber leather/gray leather seating by classic soft trim
    • suede headliner and shifter/emergency brake boots
    • evolve gauge treatment
    • silver/titanium console
    • silver interior highlights
    • evolve shifter
    • aluminum pedals
    • rear wheel wells expanded inboard to accommodate wide tires
    • carpeted trunk area
    credits
    • engineering and fabrication: mr. mano agulian
    • paint: today s autowurks, whittier, california
    • build performed at: ireland engineering, duarte, california
    fora isso, as entradas de ar ajudam a refrigerar toda a baga?a q existe ai embaixo….
    desculpa bater na mesma tecla, mas o carro eh sensacional. concordo contigo vicente, no sentido de q muitos concept cars serem invi?veis no dia-a-dia. além dos exemplos q vc citou, podemos utilizar um bem famoso que eh o plymouth prowler, q foi o trabalho de graduação de chip foose, q na criação era um roadster sem paralamas...
    o h?mi com alguns desenhos originais…
    abraços eu adoro posts com fotos... :ninja:
      Vicente Sprint
      agora fud3*…........me ensinaram errado então   :olhos:
      me explica então, como a relação area / ratio não tem nada a ver com o tamanho do rotor ????????????????
      quer dizer que são sempre valores fixos ??? todas as .48 são iguais???  :ninja:
      ps: ou bode? ..........não entendi a piadinha........  :hmm:
      algum preconceito por eu morar no nordeste???  :fiu:
      [snapback]269391[/snapback]
      nada a ver com ser nordestino
      vc não conhece a estária do bode na sala?
        overrr
        e também não conheão ahehaehae
          olha… vou ter que concordar com o vicente porque é a primeira vez que eu vejo um coletor passar entre o cabeçote e o capo. eu acho estranho. essa é a minha opinião.
          afinal, esse carro é ou não protótipo?
          mas tbm eu vi que uma chapa de aão inox com uma fita de amianto segura e muito o calor.
            voltando ao bode frio, opos vaca fria :ninja:
            ar não tem ligação direta com o rotor vc poderia ter (se a fabrica assim o fundisse) uma ar .36 pra um eixo t04 desde que respeitasse as dimensões corretas
            e é uma proporção…ali?s qual a diferença entre 48/100 e 24/50 ?... nenhum vão me dizer... mas quem prestar atenção vai perceber porque uma .42 da lacon dá resultados diferentes de uma da garret...
            porque mudando o a ou o r vc tem efeitos diferentes na aceleração do ar (que é o que o a/r nos diz)
              Tommy
              [snapback]269465[/snapback]
              eu usava uma coisa bem similar no meu opala, pq tinha aquele coletor tubular do giba q a turbina fica quase q encostada no capo. fiz um defletor de aão inox, e por dentro coloquei aramida. ficou show de bola…..super bem isolado...
              quanto ao coletor, aqui vai uma foto de uma s80 t-6, 6 cilindros em linha, transversal, biturbo....
              pix: editado para colocar uma foto menor mas com link para a original.
              outra foto do coletor da xc90 com o mesmo motor, com algumas diferenças..
                stefano
                mas o coletor desse volvo tá lá pra baixo…
                esse polvo que passa por cima do motor é pressurização só...
                tanto que é de próstico igualzinho ao meu gol city
                  [snapback]269538[/snapback]
                  eu estava comentando do coletor de escape e não de admissão.
                    esse japon?s deve di tá tomando muito saquê uahuhauhauhauha
                      Vicente Sprint
                      [snapback]269467[/snapback]
                      isso é uma coisa é que as pessoas deveriam atentar mais.
                        punkrocker
                        eu concordo com o vicente e tbm acho que ele se derrete todo qdo anda…
                        mais uma foto do volvo no auto-burn mode: on
                        pix: editado para colocar uma foto menor mas com link para a foto original.
                          Vicente Sprint
                          engenheiro, engenheiro…
                            Vicente Sprint
                            fora isso, as entradas de ar ajudam a refrigerar toda a baga?a q existe ai embaixo....
                            [snapback]269397[/snapback]
                            o carro é off-the-shelf… cara, é servião de boa qualidade, com peças de boa qualidade, mas na boa: alguém já assistiu o riddler awardá os caras montam carros com acabamento infinitamente melhor do que esse, em casa.
                            carro de show é isso aí, embora agente não esteja acostumado com esse nível de montagem por aqui, se vcs pensarem no quanto de grana rola nesse tipo de projeto, agente começa é ver as coisas com outros olhos.
                            claro que o carro é atraente e sem dúvida parece ser bem acabado.
                            mas ninguém aqui acha que isso é um carro pra usar não ??
                            ?bvio que não vai estragar nada dando umas voltinhas na frente do sema (ou sei lá pq fizeram esse carro). mas é como eu disse, desafio qquer pessoa aqui é trazer uma foto de carro de produção com o escape nesse local.
                            e dá sim pra fazer um carro que dá show parado e andando, com funcionalidade muito maior.
                            alguém não conhece o golf rsi?
                              Vicente Sprint
                              ah, e tem mais uma coisa:
                              o chip foose faz os carros mais lindos que eu já vi, mas ele é um cortador de mola inveterado ele não dá a mínima pra din?mica do carro, como todos que viram no programa onde o titus puxou a fila do power tour podem atestar
                                overrr
                                golf rsi
                                  overrr
                                  polo com a mesma mecanica do golf
                                    overrr
                                    audi quattro com a mesma mecanica dos dois….
                                      Vicente Sprint
                                      eu aposto que esse não derrete nada
                                      e se derreter também, ah, tá valendo
                                        punkrocker
                                        [snapback]269766[/snapback]
                                        :ninja:
                                        bom comentario este sobre o chip foose.
                                        todo mundo endeusa o cara, mas a equipe do programa jah apareceu vê??rias vezes cortando molas e se a tradução está correta, ele tá sempre enchendo o saco p/ socar mais um pouquinho…
                                          eu já vi o cara cortando mola tbm.
                                          mas nos carros que eles fazem eles sempre utilizam suspensão e freios de primeira.
