  4. Qual a diferença entre weber ida e idf
46 Posts 19 Posters 6.2k Visualizações 1 Watching
    agora imagina um blower em baixo disso ae :^^: :pix:
    [snapback]610899[/snapback]
    tipo assim ? ? :^^:
      RodrigoLóke
      ja responderam?  :pix:
      [snapback]610886[/snapback]
      carol, eu tinha esquecido de mandar…... :^^:
      acabei de mandar o e-mail. assim que eles responder eu posto. :(
      abraço,
        Rafael16V
        ja responderam?  :^^:
        não repare, é q ja fui loira  :^^:  :pix:
        acabou com as loiras agora :p
          RodrigoLóke
          vamos lá pessoal, estou abusando do carinha lá da redline hehehe dá até vontade de comprar, só pela atenção que o cara está dando
          dessa vez não vou traduzir não, não to com saco hahaha
          there are many smaller differances in the two carb styles. which is why one offers more flexability for tuning street only. but yes the idf does offer a choke / cold start device but that system does not offer a fast idle choke system. and no we do not offer a progressive system both sets have common cross bar linkage for smooth throttle action and funtion as single throttle opening at one time.
          i was trying to keep things compact for your information and i seem to have made things more confusing.
          i hope the pictures will help
          im sending in two parts this one contains the idf 302 kit note the linkage is simple single pull interconnect so all linkage functions as 1.
          note also that we remove the cold start device to clean up the look and mount blanking plates to cover this function. we can supply complete but find that it should not be needed for a well tuned set up.
          my next e mail will supply the ida set up
          bud pauge
          redline weber
            RodrigoLóke
            parte dois do tópico, agora falando sobre os buras ida.
            please note the pictures 302 ida examples i could not find the 302 but 351 id identical except for 1/2 inch wider spacing from bank to bank other wise the look and set up are exactly the same
            i think you can see they have a little different look due to the size variation.
            i hope this helps
            with your choice and options
            bud pauge
            redline weber
              Godones Motorsports
              :pix:
