  3. Motos
  4. Ajuda na compra de moto
Agendado Fixado Trancado Movido Motos
143 Posts 23 Posters 35.1k Visualizações 1 Watching
    make model
    hyosung gt 250r
    year
    2006
    engine
    liquid cooled, four stroke, 75° v twin, dohc, 4 valve
    capacity
    248
    bore x stroke 57 x 48.8 mm
    compression ratio 10.2:1
    induction
    26mm mikuni
    ignition  /  starting
    -  /  electric
    max power
    30 hp  22.4 kw @ 10500 rpm
    max torque
    20.6 nm @ 7300 rpm
    transmission  /  drive
    5 speed  /  chain
    frame steel, double pipe
    front suspension
    41mm oil upside down forks, 120mm wheel travel
    rear suspension
    gas shock absorber, pre-load adjustable
    front brakes
    single 300mm disc
    rear brakes
    single 230mm disc
    front tyre
    110/70 -17
    rear tyre
    150/70 -17
    seat height 795 mm
    dry-weight
    168 kg
    fuel capacity
    17 litres
    [snapback]691038[/snapback]
    gtr não é a 650 ???
    :ops:
      gtr não é a 650 ???
      :ops:
      [snapback]691180[/snapback]
      tem 250 e 650 :ops:
      make model
      hyosung gt 650r
      year
      2005
      engine
      liquid cooled, four stroke, 90° v twin, dohc, 4 valve
      capacity
      647
      bore x stroke 81.5 x 62 mm
      compression ratio
      induction
      ignition / starting
      • / electric
      max power
      79 hp 58.9 kw @ 9000 rpm
      max torque
      68 nm @ 7500 rpm
      6 speed / chain
      front suspension
      rear suspension
      swinging arm, 100mm wheel travel.
      front brakes
      2x 300mm discs
      rear brakes
      single 230mm disc
      front tyre
      120/60 -17
      rear tyre
      160/60 -17
      dry-weight
      191 kg
      standing ¼ mile
      13.0 sec
      top speed
      203.8 km/h
      fuel capacity
      17 litres
        http://images.orkut.com/orkut/albums3/atga…wr1prwxzqyq.jpg
        http://images.orkut.com/orkut/albums3/atga…m6oyverv7fa.jpg
        http://images.orkut.com/orkut/albums3/atga…qcirptpgmoq.jpg
        http://images.orkut.com/orkut/albums/atgaa…xgv1imsc9wg.jpg
