  4. Bicos baratos
Bicos baratos
56 Posts 11 Posters 8.3k Visualizações 1 Watching
    rtkw
    bom pessoal, fiz a compra hoje no site recomendado. tomara que de tudo certo
    optei pelos bicos de 60lbs, sera usado num passat 1.8t 99 mecanico, com intensao de acertar o chip com o overspeed no etanol.
    estou colocando filtro de ar spa, bomba walbro 255 interna, tirando o catalizador e fazendo a saida de turbina em 3pol.
    espero que fique legal
    se alguem quiser comentar, eu agradeco
    ronaldo
      walbro + etanol = fail
        a minha tá c + de 2 anos na boa….....e as vezes deixo + de 15 dias parado
        existe a walbro americana , e a walbro chinesa (já comprei as duas)
        a niquelada é a verdadeira e aguenta na boa
        dá uma olhada nesse anúncio (engana brasileiro esperto)
        http://www.ebay.com/itm/acura-rsx-autophonics-fuel-pump-2002-2007-255-lph-hp-/290556022707?pt=motors_car_truck_parts_accessories&vxp=mtr&hash=item43a67d0fb3
        we offer free 2-3 day shipping to 50 states no other seller on ebay offer this.
        this listing include autophonics industries usa 255 lph high pressure fuel pump, installation kit and installation instructions. these fuel pump will support up to 600 horsepower these are great for tubro , supercharged and na applications. if you are going to replace your fuel pump you can either meet or exceed the manufacturer s requirment for your vehicle needs. extra fuel that get sent to your engine will get sent back to your gas tank via your fuel return line, which will cool down your engine. so extra fuel will not hurt your engine because any unused fuel will get sent back to the gas tank by your fuel pressure regulatr via the fuel return line.
        this autophonics industries usa fuel pump are direct replacement of the your oem pump they are intank replacement pumps. our fuel pump will include installation kit, and installation instructions. we include the correct installation kit for each application for easy installation.
        autophonics fuel pumps are a direct install replacement for the stock fuel pump. each fuel pump includes an installation kit with the hardware required for an professional or do it yourself installation. please note that these fuel pumps may be smaller than your stock fuel pump. the diameter and even height of the fuel pump does not make any difference. as long as you can get the fuel pump mounted onto your fuel sending unit and the filter rests towards the bottom of the fuel tank, you should be good to go. we have spent months doing r&d with the applications we list and include application specific installation kits for those vehicles that require it.
        features:
        • operates between 0-115 psi (40 psi and 235lph at 13.5v)
        • performs identical or better to the walbro 255 lph high pressure fuel pumps (gss340, gss341, gss342)
        • autophonics industries usa (very low noise operation) / walbro = (noisey)
        • iso 9002 and iso/ts 16949 certified on all autophonics fuel pumps
        • warranty - (autophonics 1 years) - walbro (no warranty)
        each pump will only fit the application listed this is not a universal fuel pump.
        we offer a one year no question ask warranty if for any reason your fuel pump fails on you, just ship it back and we will replace it for you and we will even pay for shipping.
        we have been a walbro dealer for over 7 years on ebay these autophonic 255lph hp pump exceed our expectation you will not be disappointed.
          rtkw
          pois e caros colegas, no meio automotivo nao e dificil ver coisas que deixariam ate o pai da fisica em duvidas…hehehe
          ja usei bomba a gasolina empurrando etanol por mais de 3 anos, quando travou, coloquei uma flex (original) que nao durou metade.
          ja vi nego nao trocar oleo de uma chevy 500, so completava, e rodar mais de 400mil km.... tudo bem que ele rodou ate nao sobrar mais nada, mesmo assim ne?
          da mesma maneira que dois motores identicos, mesmo recem saidos de fabrica nao se comportam da mesma maneira.... vivemos neste universo relativo
            se fosse pra pegar uma bomba lá de fora , ficaria com uma bosch 044 ou 040 (uma é inline e a outra intank)…tem desempenho a 4bar melhor do que as walbro...e suportam alcool.
            walbro => marwall (magnetti marelli) e algumas delas são conhecidamente fracas ao uso de alcool... o gaucho é um caso de sucesso, mas numa oficina que eu atendo tem 3 golf com mais de 300cv com walbro, todos deram problemas ao ficar parado mais de 15 dias...
              rtkw
              sendo assim, vou estudar uma troca. tres carros parados nao e bom sinal…
              overspeed, mandei uma mp dias atras, gostaria de fazer uma cotaçao.
              no aguardo
                rtkw
                bom pessoal, minha encomenda (4 siemens deka 60lbs)foi tributada.
                19/12/2011 15:30 ctci sao paulo (geexp) - sao paulo/sp encaminhado
                em trânsito para rfb - tributado - emissão nts
                expliquei ao gringo direitinho, para nao enviar como eletronico, valor declarado ate 50,00 dolares e etc.
                vamos ver quanto o cara realmente declarou, e quanto terei que pagar nessa porcaria.
                ronaldo
                  quanto o cara declarou é o de menos. se o fiscal encanar ele tributa pelo valor q ele bem entender :d
                  comprei um kit coaxial no e-bay por u$ 40,00, somado com o frete deu coisa de u$70,00 tudo. qdo fui buscar no correio, me cobraram r$500,00 - isso mesmo, quinhento reais - só de imposto.
                  infelizmente essa de mandar como gift e abaixo de u$ 50,00 não cola já faz tempo.
                    existe uma tabela de valores mínimos e máximos…..............e vc pode entrar c recurso e tentar provar q teu preço tá certo
                    mas se vc tentou enganar, sentou na jojola
                      pior que não gaucho…
                      lá nos eua eles vendem itens de vitrine / fora da embalagem original por preço de banana, e foi isso que aconteceu. paguei 40 de um kit componente que custava quase 150 dólares.
                      entrei com recurso, levei a fatura do cartão e imprimi o anúncio do ebay, mas não adiantou.
                        seguinte, sua amostra deve ter caído no raio-x. por mais que tenha declarado um valor menor, a receita tem uma tabela dos preços, então eles irão pesquisar quanto vale um bico injetor siemens deka 60lb, e em cima desse valor irão jogar os tributos.
                        se foram 4, prepara o bolso, na época, ano passado eu paguei cerca de r$380, isso porque o dolar era cotado na casa de 1,65. creio que no seu caso vá para uns 400 reais.
                        lembro que a primeira vez que comprei, ele declarou us48, maaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaas na descrição do produto colocou o nome dos bicos, 4 unidades, e o nome da loja e estava especificado como eletronic parts, ai ferrou.
                        depois comprei +2 bicos e vieram numa boa, o cara colocou car parts.
                        a receita ve eletronic e já tributa mesmo, pode ser eletronico de celular, computador, carro… dificilmente passa ileso.
                        e vc pegou uma época horr´vel pra compra internacional. fiscalização é maior.
                        e qual foi o envio? first classó sempre opte por ele. priority mail e tem um outro que é equivalente ao sedex, esses já são mais visados.
                          lembro q a malandragem era pagar + da metade em dinheiro e o resto no cartão
                          depois mostrava a fatura do cartão c o preço menor
                          eles estão espertos c isso
                          não falei q é seu caso, mas já ví muitos assim.
                            rtkw
                            e pessoal, esta e a quarta compra no exterior e a primeira tributada.
                            hoje cedo ao conferir o rastreio fiquei muito puto, mas sao coisas da vida ne…. vivendo e aprendendo.
                            desconfio que o cara colocou remetende juridico.
                            gaucho, esse lance de dividir o valor e interessante, ou usar dois cartoes ne... ai na hora de confrontar as informacoes so levar a fatura de um deles e resolver o assunto.
                            estava animado para trazer uma bomba bosch 040 ou aeromotive e mais algumas coisas, devagar... mas neste momento recordo de uma vez que estava no motel todo animado, quando fui ligar a hidro tomei um puta de um choque que quase travou minha biela....kkkk
                            agora resta ver quanto pagarei de imposto aos vampiros.... comentarei apos o recebimento a experiencia.
                            ronaldo
                              acontece. um dia é da caça o outro é do caçador. já rodei várias vezes com tributação, mas já passei cada coisa que valeu muito a pena hehe.
                                rtkw
                                bom pessoal, conforme combinado aqui estou p contar minha experiencia.
                                o remetente usou o nome juridico, como eu desconfiei. contudo, eu nao pedi p ele colocar como pessoa fisica.
                                fui tributado sobre o valor declarado de 50dolares + frete = 93,27 reais.
                                fiquei aliviado, pois mesmo com essa tributacao o valor compensou (total de 540,00).
                                aproveitando que esta semana estarei de folga, amanha vou buscar uns tubos de inox para a pressurizacao e saida de turbina.
                                quando estiver na fase de montagem, iniciarei um topico para dividir com a galera
                                ronaldo
                                  rodrigovom
                                  ronaldo
                                  ae ronalds… estou no mesmo processo que vc. estou pensando em comprar 4 bicos, so que é de outro fornecedor e nao do site da siemens...
                                  quais serias as informações que devo pedir para o fornecedor colocará algum nome sem ser o juridico, carparts, valor ate 50usd???
                                  seria basicamente isso ou tem mais alguma dica?
                                  e de lugares da china, alguem ja comprou? tem coisas bastante interessantes por lá, bicos de 160 lbs por exemplo saem a menos de 18usd cada unidade em alguns fornecedores, so que ai tem que convencer os caras a mandar somente poucas unidades... rs
                                    rtkw
                                    rodrigo, ja comprei da china tb, um cabo vag e um timer da apexi que tem hallmeter e voltimetro, ambos por menos de 50 dolares com frete. chegaram em duas semanas.
                                    a legislação preve que toda encomenda, cujo remetente seja uma pessoa juridica, seja taxada. so nao e taxada encomendas cujo conteudo seja livro ou se o remetente seja uma pessoa fisica e a encomenda seja abaixo de us$50.00. fora desses casos, existe a chance de ocorrer a taxacao, independente do valor do produto.
                                    se o vendedor aceitar enviar a voce nessas condicoes, pelas leis voce nao sera tributado, mas se o fiscal abrir sua encomenda para verificacao e ver que o valor nao e real, ele ira consulta uma tabela de valores e aplicara os 60%, as vezes ate mais se quiser (18% icms - sp).
                                    estou com intensao de comprar um bomba interna da aeromotive por us$190.00 com frete no inicio do ano. na dinamica custa r$700.00.
                                    e mais uma vez, vou arriscar e torcer com toda certeza hehehe
                                    boa sorte
                                    ronaldo
                                      rodrigovom
                                      então seria pedir pro vendedor colocar algum nome fisico , declarar o valor até us$50,00 e só? ou tem mais alguma coisa? tem algum site que vc recomenda? de agora pra frente já é um período legal pra se comprar?
                                      essa aeromotive ai tá no jeito heim… manda vê
                                      desde já, obrigado e um feliz ano novo a todos os amigos aqui do pp :cerva:
                                        eu não vejo razão para comprar bomba importada. tenho usado as da dinâmica já faz um certo tempo e nunca me incomodei com isso.
                                          rtkw
                                          ricardo, com certeza a empresa que voce mencionou esta no mercado a bastante tempo prestando serviços de qualidade de acordo com muitos clientes.
                                          eu pretendo utilizar uma bomba interna, sei que na dinamica eles montam bomba externa (tipo gti) dentro do copo, inclusive, muitos anos atras quando eu trabalhava em oficina ja fiz isso em alguns carros.
                                          contudo, o preço de r$342,00 por uma bomba muito confiavel (aeromotive), simples de adaptar(tamanho) e que forneça 340lbs soa bem interessante, concorda ?
                                          claro, desde que os homens de preto nao se interessem pelo conteudo da caixa (impo$to$)….hehehe.
                                          tenho preferido essas peças de fora pq estou sem pressa de montar a jaca (passat 1.8t b5), comprei uns tubos de inox dias atras para escape e pressurizaçao.
                                          devagar nois chega la hehe
                                          grande abraço
